Hi,
In Inventor 2010 when making a final drawing, there's an "Arrange Dimension" command. It works very well for dimensions arranged vertically, but the spacing is too small horizontally. Is there a way to change the horizontal spacing? I've looked all over, but can't find one.
Any help would be great. Thanks.
It's in the Styles editor. Under Dimension, Display tab, look for Spacing. It effects both horizontal and vertical dimensions. You could set up a style for both with different settings.
ecshclark is correct, that setting effects both the horizontal and vertical settings at the same time. I put in a wish list item a while back asking for the settings to be broke out into two separate settings but it didn't happen in 2011. Hopefully they will make this change in 2012.
Cool! Thanks guys.
Yeah, having them work together is kind of a pain, but at lest I can get it done.
