Script Pro Script help
Emily_83
Morning Guys
i was wondering if you could help me, i am after a batch Script for Scriptpro to delete a block out of multiple drawings, and then insert another in it's place at 0,0, then qsave
could anyone help me? if you need any more info let me know!!
Cheers
:DEmily:D
Hi Emily
I think it is better to use Lisp instead of writing dummy codes for Script file, So you can take a start with this .
(defun c:try (/ blkNmr pt)
 (setq blkNme (getstring"\n Enter Name of Block: "))
(while (setq pt(getpoint "\nSpecify Block insertion point: "))
      (vl-cmdf "_.-insert" blkNme pt "" "" "")
And you can add the command Qsave and Exit to codes as well ...... agree?
Regards
Tharwat
A few questions Emily:
  • Would the new block be at every instance of the old block, or would it just be at 0,0,0?
  • (Related to the above) Would the new block be inserted at 0,0,0 even if the drawing did not contain the old block?
Lee
Hi Emily
Regards
Tharwat
Good morning Tharwat,
thankyou for your time i will give this a go.
Cheers
Emily
Lee
Good Morning Lee
the New block is the same name as the old block, it has jsut been modified and resent to us to change over so when we insert it it will be inserted at 0,0, so yes it would be at every instance of the old block as the old block is at 0,0.
does that answer your question or have i confused us both even more?
lol
i need a coffee.......
thankyou again for you help Lee
Cheers
Emily
That explains things better Emily, thanks - you are just redefining the block definition by the sound of it.
I wrote this a while back for such a purpose - there are two versions, the first offers a user prompt, the second is for use within a script.
(defun c:ReDef ( / *error* GetActiveSpace spc nb un )
 (vl-load-com)
 ;; Lee Mac  ~  22.04.10
 (defun *error* (msg)
   (and un (vla-EndUndoMark doc))
       (princ (strcat "\n** Error: " msg " **")))
   (princ))
 (defun GetActiveSpace (doc)
   (if (or (eq AcModelSpace (vla-get-ActiveSpace doc))
           (eq :vlax-true   (vla-get-MSpace doc)))
     (vla-get-ModelSpace doc)
     (vla-get-PaperSpace doc)))
 (setq spc (GetActiveSpace
             (setq doc (vla-get-ActiveDocument
                         (vlax-get-acad-object)))))
 (if (setq nb (getfiled "Select Block" "" "dwg" 16))
     (setq un (not (vla-StartUndoMark doc)))
     (vla-delete (vla-insertblock spc
                   (vlax-3D-point '(0 0 0)) nb 1. 1. 1. 0.))
     (vl-cmdf "_.attsync" "_N" (vl-filename-base nb))
     (setq un (vla-EndUndoMark doc))))
 (princ))
(defun ReDef ( block / *error* oc spc doc block )
 (vl-load-com)
 ;; © Lee Mac  ~  21.06.10
 (defun *error* ( msg )
   (and oc (setvar 'CMDECHO oc))
 (setq spc
   (if
     (or
       (eq AcModelSpace
           (setq doc
 (setq oc (getvar 'CMDECHO)) (setvar 'CMDECHO 0)
 (if (setq block (findfile block))
     (vla-delete
         (vlax-3D-point '(0. 0. 0.)) block 1. 1. 1. 0.
     (vl-cmdf "_.attsync" "_N" (vl-filename-base block))
Call the above with
(Redef "C:\\Users\\Emily\\Block.dwg")
Let me know if you run into trouble,
Lee
 (vl-load-com)
   (princ))
 (princ))
 (vl-load-com)
 (setq spc
   (if
     (or
       (eq AcModelSpace
           (setq doc
       (eq :vlax-true (vla-get-MSpace *doc))
     (vla-delete
Call the above with
Lee
Hi there Lee,
thankyou so much for your time and help.
though not know much about Lisp and Scripts still, i need some direction.
i have copied and pasted the 2nd option for script into notepad and then saved it as a REFDEF.lsp
then i opened a new notepad and wrote a script to run the REFDEF.lsp like so
(LOAD “O:\\Projects\\TEMP\\Emily E\\REDEF.LSP”)
REDEF
QSAVE
and i saved that as REDEF.scr
is that what i should be doing?? i have no idea as i only got scriptpro on Monday and have only created 1 easy script which was to batch purge and audit the drawings.
next question is (i know this may seem stupid) but the block i am wanting to delete and replace (or refedit) is CIVIL_TB_A1
where about in the 2nd lisp routine you supplied do i enter that??
could you possibly highlight in red where i should place it?
thankyou in advance for your help
Cheers
Emily
Hi Emily,
You don't need to modify the LISPs I have posted in any way :)
My code assumes that the block you are replacing has the same name as that which you are replacing it with, hence just one argument is needed - the replacement block.
Call my second option like this:
(ReDef "C:\\Users\\Emily\\Block.dwg")
as posted in my earlier post - it is not to be called at the command line, but rather as a subfunction taking one argument: the filename of the new block. (Just as you called the LOAD function with one argument).
I have never used ScriptPro, so I cannot advise you on that.
Before using the script, test my function at the command line typing the above.
Lee
apologies Lee,
but what do you mean "Call your second option like this"? i can see the Code you have supplied me with but where do i place that..??
i should have training wheels on i know.
Cheers
Try typing it at the command line for example. Just as you are calling the 'load' function - treat my function as if it was any other LISP function taking arguments.
eg.
(load <filename> <onfailure>)
(ReDef <blockfilename>)
eg.
Hey there Lee,
thankyou very much i thought that is what you meant,
the problem i am getting now though is the following error
** Error: bad argument type: VLA-OBJECT nil **
any clue what that means?
thankyou for you help and patience
Cheers
Emily
Hi Emily,
I did spot a minor typo in my second code (just updated) that would affect it if you were running it when looking through a viewport - perhaps this caused your error.
Lee
