I have a drawing which when opened displays a message that states: "This application has detected objects from a newer version of this drawing."
How can I determine what objects it has found and how to purge these objects to remove them and eliminate this message?
I am in LD 2008.
I don't know of any way to identify the objects.
As far as purging them, you can try to do an Export to Autocad 2007 format. But you might be missing objects, and may need to go back to the source of the drawing, and ask them to give you an Export to Autocad 2007 format from their software.
