Hi,
I'm using Autocad Lt 2007. When I insert a survey as an xref into my drawing the contour lines show up whereas they don't show up when I'm in the survey itself. I've turned off the layer (0) on which the contours are located but they still crop up in my destination drawing.
It's probably due to the objects being on the 0 layer. Move them to their own unique layer and try again - should fix it.
Yes, that would do it..! Thanks (for the second time..)
Corinne
