Lucas Posted July 13, 2010 Posted July 13, 2010 Hello guys ... Well I was installing AutoCAD 2010 x64 then an error ocurred. It was 1308, then I read on autodesk website that I should copy the archives from CD to the HD. So I did exactly what that said but this error is still ocurring. Any ideas to solve this problem ? Thanks anyway Sorry my bad english ... Quote
rkmcswain Posted July 13, 2010 Posted July 13, 2010 Did you copy both disks to the same directory? See: http://support.autodesk.com/getDoc.asp?id=TS1065392 Quote
rkmcswain Posted July 14, 2010 Posted July 14, 2010 Do you mind sharing, so that future readers can benefit? Thanks. Quote
ufuquest Posted February 2, 2011 Posted February 2, 2011 Hello everyone! I'm using windows 7 ultimate 64 bit and i want to set up autocad 2010 64 bit version. When i start to installation i receive the "ERROR 1308 ... " There is two button appear on the error message box . One of it is "Try again" and other is "Cancel" . What is the problem. I searched at google but results are not fix my problem. Maybe problem is related to windows update.??? (.NET Framework,.. etc. ?? ) I tried to install it on updated win7 at another PC. It is installed correctly. Please help... Thanks... Quote
