Hi,
In the past I have changed an existing VBA code so it fits my needs. But now my needs are changed. It was witten to open a block from de Blocks folder in the drawingfolder. But now I want it to be opened from the Blocks folder in a parent folder. There a way to find a certain string in the ThisDrawing.Path and change it to Blocks, but I can't figure it out.
My folder stucture is something like this:
E:\Documents\10.001 Project\CAD\subdir\
E:\Documents\10.001 Project\CAD\subdir\subdir\drawing.dwg
It needs to be something like:
E:\Documents\10.001 Project\CAD\blocks\blockdrawing.dwg
Can anybody give me some advise?
DAMO
Sub Start()
   Dim DwgName, BlkMapName, BlkName As String
   Dim DwgMapName, MapNameNew As String
   Dim objEnt As AcadObject
   Dim varPnt As Variant
   BlkMapName = ThisDrawing.Path + "\blocks\"
   ThisDrawing.Utility.GetEntity objEnt, varPnt, "select block"
   If objEnt.ObjectName = "AcDbBlockReference" Then
       BlkName = objEnt.Name
   Else
       MsgBox "selected item is not a block": Call Start
   End If
   ' Looks for the block in de map Blocks in current workmap
   DwgName = BlkMapName + BlkName + ".dwg"
   If Dir(DwgName) <> "" Then
   ThisDrawing.Application.Documents.Open DwgName
   Else
   MsgBox ("Block bestaat niet in map. ")
   End If
End Sub
Solved it myself!
This is the new code:
Sub Start()
   Dim DwgName, BlkMapName, BlkName, ProjMapName As String
   Dim DwgMapName, MapNameNew, MapNameNew2 As String
   Dim varTel As Variant
   DwgMapName = UCase(ThisDrawing.Path)
   MapNameNew = Replace(DwgMapName, "\CAD\", "\CAD\blocks\")
   varTel = InStrRev(MapNameNew, "blocks")
   BlkMapName = Left(MapNameNew, (varTel + 6))
   Else
   End If
   MsgBox DwgName
   Else
   End If
End Sub
