My Company runs AutoCAD LT 2008
One of the PM's I work with is having problems getting to the Publish Options. He needs to change the Layer option to Publish with Layers but he is unable to get the Publish Options window to open and not lock up his AutoCAD. I also had him try to go through the Options-Plot & Publish and see if that would give him any other result. We have rebooted the PC and tried to launch AutoCAD and then try with no luck.
I dont want to have to re-install his AutoCAD. Any Ideas on what I need to do?
Thanks
Shelley
Check under options, then go to the Plot and Publish tab. Make sure Enable background plot option is not checked. I had issues with that option in the past locking up AutoCAD.
Hope this helps.
Scott
  • 1 year later...
sab 423 THANKS! I was having the exact same problem and unchecking the enable background plot option solved it. You da man!
