setAttributeFromBlock()???? .NET
Using ObjectARX via the Managed Classes (VB.NET for a language)....
So, I can insert a block from an external DWG file. That is fine.
The problem I am now having is with the attributes. That DWG has several attributes (part number, etc) which are VISIBLE attributes. When I insert this DWG into another drawing via .NET the attributes do not seem to be present! I have seen reference to the SetAttributeFromBlock() function, though I am a bit unclear on using it.....
