dpaulku Posted July 15, 2010 Share Posted July 15, 2010 This is an embarrassing question, but is there a lisp routine that will round decimal places once the text is placed? This has nothing to do with the units settings; this would be just editing dumb text elements already in the file. I don't write code but I imagine that a text string could be evaluated for numbers, a decimal point and a number of characters there after. I'd even be happy with truncating the last/extra character if it couldn't be rounded. I mistakenly exported a whole lot of number data out of one POS (Piece of Software) with three point rounding in the digits. I need/want only two so that my crew won't think I'm being **** retentive. Any hope for this? Thanks in advance Quote Link to comment Share on other sites More sharing options...
alanjt Posted July 15, 2010 Share Posted July 15, 2010 (defun c:R2D2 (/ ss) (if (setq ss (ssget "_:L" '((0 . "TEXT")))) ((lambda (i / e l) (while (setq e (ssname ss (setq i (1+ i)))) (setq l (entget e)) (entmod (subst (cons 1 (rtos (atof (cdr (assoc 1 l))) (getvar 'lunits) 2)) (assoc 1 l) l)) ) ) -1 ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
dpaulku Posted July 15, 2010 Author Share Posted July 15, 2010 OK, so it wasn't that hard. Where do I send the money? Very much appreciated, you just saved my morning! xoxo ...Ooops, may have spoke too soon. This works well on a per pick basis but if I select by window en-mass, unpredictable results show up. example: (selected as a set all separate text entities) CL Elev: 1278.141 Gnd Elev: 1277.952 DitchElev (LT) 1267.800 yields: 0.00 1278.14 0.00 1277.95 0.00 1267.80 Perhaps it's harder to diferentiate alpha from numeric? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 15, 2010 Share Posted July 15, 2010 (defun c:R2D2 :lol: Quote Link to comment Share on other sites More sharing options...
alanjt Posted July 15, 2010 Share Posted July 15, 2010 OK, so it wasn't that hard. Where do I send the money? Very much appreciated, you just saved my morning! xoxo Some other time. You're welcome. :lol: LoL RoundToDecimalsofTwo It was just too perfect. Quote Link to comment Share on other sites More sharing options...
dpaulku Posted July 15, 2010 Author Share Posted July 15, 2010 see my edited xoxo post Quote Link to comment Share on other sites More sharing options...
alanjt Posted July 15, 2010 Share Posted July 15, 2010 Ugh, you didn't tell me the text was something other than just a number. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 15, 2010 Share Posted July 15, 2010 Not much different from Alan's code, keeping with the theme lol (defun c:C3PO ( / ss ) (if (setq ss (ssget "_:L" '((0 . "TEXT")))) ( (lambda ( i / e el ) (while (setq e (ssname ss (setq i (1+ i)))) (if (distof (cdr (assoc 1 (setq el (entget e))))) (entupd (cdr (assoc -1 (entmod (subst (cons 1 (rtos (atof (cdr (assoc 1 el) ) ) (getvar 'LUNITS) 2 ) ) (assoc 1 el) el ) ) ) ) ) ) ) ) -1 ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
alanjt Posted July 15, 2010 Share Posted July 15, 2010 Not much different from Alan's code, keeping with the theme lol Nice idea to check string with distof. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 15, 2010 Share Posted July 15, 2010 Nice idea to check string with distof. Thanks man Quote Link to comment Share on other sites More sharing options...
dpaulku Posted July 15, 2010 Author Share Posted July 15, 2010 I'll quick check it. You guys are amazing. Sorry that I left out that bit about not all the text being numbers... ... now it's hugs all round! Thanks again. Quote Link to comment Share on other sites More sharing options...
alanjt Posted July 15, 2010 Share Posted July 15, 2010 So, are they all prefixed with a string? Post an example drawing. I'm going to lunch, but I'll have some time later today. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 15, 2010 Share Posted July 15, 2010 ... now it's hugs all round! Thanks again. Excellent Just for completeness, assuming decimals only - this should account for numerical text mixed up with alpha: (defun c:2dp ( / ss ) ;; © Lee Mac 2010 (if (setq ss (ssget "_:L" '((0 . "TEXT")))) ( (lambda ( i / e ) (while (setq e (ssname ss (setq i (1+ i)))) (entupd (cdr (assoc -1 (entmod (subst (cons 1 (apply 'strcat (mapcar (function (lambda ( item ) (if (eq 'INT (type item)) (itoa item) (if (eq 'REAL (type item)) (rtos item 2 2) item ) ) ) ) (LM:ParseNumbers (cdr (assoc 1 (entget e) ) ) ) ) ) ) (assoc 1 (entget e)) (entget e) ) ) ) ) ) ) ) -1 ) ) (princ) ) (defun LM:ParseNumbers ( str / isString isNumber lst tmp ) ;; © Lee Mac 2010 (defun isString ( x lst ) (cond ( (null lst) (list x)) ( (< 47 (car lst) 58) (cons x (isNumber (chr (car lst)) (cdr lst))) ) ( (= 45 (car lst)) (if (and (cadr lst) (numberp (read (setq tmp (strcat "-" (chr (cadr lst))))) ) ) (cons x (isNumber tmp (cddr lst))) (isString (strcat x (chr (car lst))) (cdr lst)) ) ) (t (isString (strcat x (chr (car lst))) (cdr lst))) ) ) (defun isNumber ( x lst ) (cond ( (null lst) (list (read x))) ( (= 46 (car lst)) (if (and (cadr lst) (numberp (read (setq tmp (strcat x "." (chr (cadr lst))))) ) ) (isNumber tmp (cddr lst)) (cons (read x) (isString (chr (car lst)) (cdr lst))) ) ) ( (< 47 (car lst) 58) (isNumber (strcat x (chr (car lst))) (cdr lst)) ) (t (cons (read x) (isString (chr (car lst)) (cdr lst)))) ) ) (if (setq lst (vl-string->list str)) ( (if (or (and (= 45 (car lst)) (< 47 (cadr lst) 58)) (< 47 (car lst) 58)) isNumber isString ) (chr (car lst)) (cdr lst) ) ) ) Quote Link to comment Share on other sites More sharing options...
alanjt Posted July 15, 2010 Share Posted July 15, 2010 Well, I won't bother then. Quote Link to comment Share on other sites More sharing options...
dpaulku Posted July 15, 2010 Author Share Posted July 15, 2010 So, are they all prefixed with a string? Post an example drawing. I'm going to lunch, but I'll have some time later today. I could do that but I'd have to put everything back! C3PO works as expected with some exceptions so far: It wouldn't resolve 2.500% to 2.50%. It ignored it altogether. If a number had no decimal point, ie "1255" it resolved those into "1255.00". For text representing stations, "24+00.000"... that got resolved into "0.00". Not sure what's going on there but the "+" has to be the culprit. (Ordinarily I'd go with 24+00 but I can live w/.00) I'm working with cross sections dumped out of a POS and there's a ton of them that have been heavily edited. I couldn't just go back and change the precission and re-export cause... well, it's a long story. Anyway within my problem graphic pile I have elevations of grid lines (1255), offsets from centerline ("-10" left and "10" right), elevations of ground points on the sections (1245.32), stations in "0+00" format and grades as percents (2.55%). Also the other "info text" for specific section features like cross slopes, elevations at centerline and at ditch bottoms. 'Not surprised really that this quick code wouldn't do everything. I got around the warts with some quick search and replace... took two minutes. To have all my numbers now fixed is a big big help. If nothing else I've learned to be aware of the number of decimal places I'm running in diferent apps as they do share data on a regular basis. Thanks all once again. ...Wait!, I do have a sample section that was cut to build the full set so I'll send it on for your info. v2010 ed: While I was typing this blurb Lee augmented the code. It's either lunch break on your end or you guys are lightning typists and robotic code generators! I'll test the latest version over lunch here in Frostbite Falls... 67506-WESTXSECTIONS-Sec1902.dwg Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 15, 2010 Share Posted July 15, 2010 Did you try the code in post #13? Quote Link to comment Share on other sites More sharing options...
dpaulku Posted July 15, 2010 Author Share Posted July 15, 2010 trying it now... command "2dp" doesn't seem to be working... It does load w/o error but then perhaps there is no test done at load in. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 15, 2010 Share Posted July 15, 2010 Works fine for me - what error do you get? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 15, 2010 Share Posted July 15, 2010 Well, I won't bother then. Hope I didn't 'burst' your 'bubble' Alan Quote Link to comment Share on other sites More sharing options...
alanjt Posted July 15, 2010 Share Posted July 15, 2010 Hope I didn't 'burst' your 'bubble' Alan My bubble? Quote Link to comment Share on other sites More sharing options...
