(sssetfirst nil (ssget "_X" '((0 . "INSERT") (10 . 0.0 0.0 0.0))))
  • Replies 32
  • hunszab
    16
  • Tharwat
    7
  • Lee Mac
    6
  • The Buzzard
    3
Hi all!
How can I select every object that is in a specific point?
To be more specific... I have blocks, so they have just one point. And I want to select a block that point is i.e. (0,0) or (x,y).
So how can I do that?
Thanks any help
Try the following to be saved with a variable ...
(setq BLK (ssget "_x" '((0 . "INSERT")(10 0.0 0.0 0.0))))
Regards,
Hi all!
I have 2 points (or n points) and I want to create an LWPOLYLINE. How can I do that?
I've tried this:
(entmake
(list
(cons 0 "LWPOLYLINE")
(cons 8 "0")
(cons 10 point1)
(cons 10 point2)
but doesnt work...
Thanks any help!!
Thanks!
It's good.
Now I have another problem.
I have a macro which contains a function, when I call it where will I get that it returns?
On the prompt or system variable or where? Because it always returns nil...
Any help ?
Your question is not a clear at all my friend ......
Give a direct question.
Any help ?
The never-ending stream of questions....
The function call itself will provide the function return, i.e.
(myfunction)
==> Return
I try to be specific.
I have a dwg file, macro included. In the macro there are a lot of function.
For example, when I call the function I will return the result like I would have called an autolisp function or I return the result in a specific system variable?
(command "-VBARUN" "mymacroname.mymacrofunctionname")
I ask this, because when I use this command it always return nil, but it should have return something else..
I hope I was clear enough.
thanks any help
When you use Lisp in a macro, there is no need for (command) .... just write the name of the command directly. things like :
^C^C_-VBARUN.......... THE REST ...
But if you use a complete lisp in a macro, it is better to call only the name of the Lisp program.
Regards
thanks, I've allready found the solution.
Hi!
I have the following problem:
I want to build a menu that has 2 popup_list and I want to bind the first popup_list to a dotted list first , the second popup_list to the dotted list second part.
I.G: I have this list "mylist" : ( ( 1 . "first") (2 . "second"))
how should I modify my command?---> (mapcar 'add_list mylist)
thanks any help!!!
Many ways to approach it, one of which may be:
(mapcar
'(lambda ( key lst )
   (start_list key)
   (mapcar 'add_list lst)
   (end_list)
'("key1" "key2")
 (list (mapcar 'car mylist) (mapcar 'cdr mylist))
