autolisp Posted July 16, 2010 Posted July 16, 2010 dear all please chk some error at code (defun c:txa()(setq dclname (cond ((setq tempname (vl-filename-mktemp "txa-tmp.dcl") filen (open tempname "w")) (foreach stream '( "txa:dialog{\n" " label=\"tt\";\n" " :popup_list{ \n" " key=\"align\";\n" " edit_width=10;\n" " allow_accept=true;\n" " }\n" " spacer;\n" " ok_cancel;\n" " }\n" "\n" ) (princ stream filen) ) (close filen) tempname ))) ;;-------------- (defun txa-show_popup_list (key slist) (start_list key) (mapcar 'add_list slist) (end_list) ) ;;------------ (defun txa-show_popup_list_vlaue (index key slist) (set_tile key index) (nth (atoi index) slist) ) (setq alignname_lst '("Left" "Right" "Align" "Center" "Top right" "Top left" "Center" "Middle right" "Middle left" "Lower Left" "Lower right")) (setq dclid (load_dialog dclname)) (new_dialog "txa" dclid) (txa-show_popup_list "align" alignname_lst) (action_tile "align" "(txa-show_popup_list_vlaue $value "align" alignname_lst)") (start_dialog) (unload_dialog dclid) (vl-file-delete dclname) ) Quote
