dtaylor Posted July 16, 2010 Posted July 16, 2010 I have these two solids. I want to subtract the long thin one from the round wide one. When I try, nothing happens. Any idea why? manhole invert 3d.dwg Quote
fahim108 Posted July 16, 2010 Posted July 16, 2010 Very strange indeed! ...how did you model it? ...I hope you didn't copy-paste it from an older version of cad? Quote
dtaylor Posted July 16, 2010 Author Posted July 16, 2010 i drew it from scratch in 2011 using cylinders and boxes and snapping them to needed points. i saved it as a 2004 version for the forum so more people could open it. Quote
JD Mather Posted July 16, 2010 Posted July 16, 2010 How far from the 0,0,0 origin are you modeling? CAD programs don't like to be far from 0,0,0. I checked the geometry in a next-generation 3D CAD program and it reported problems with the geometry. Quote
JD Mather Posted July 16, 2010 Posted July 16, 2010 Unstitched, Refit, Stitched and all is well. But I would ask how you are going to manufacture that - the cut results in an infinitely thin intersection. In the real world some cuts will break through resulting in a nasty burr. (actually all parts will show a buldge from tool pressure. Quote
dtaylor Posted July 16, 2010 Author Posted July 16, 2010 I ended up redrawing it and subtracting each section of solid as I drew it. Quote
dtaylor Posted July 16, 2010 Author Posted July 16, 2010 Its a concrete channel poured in the base of a manhole Quote
JD Mather Posted July 16, 2010 Posted July 16, 2010 Try this one (acisin). I ended up redrawing it and subtracting each section of solid as I drew it. Oops. ACIS.zip Quote
dtaylor Posted July 16, 2010 Author Posted July 16, 2010 Thanks though. Any idea why a problem like that pops up? Quote
JD Mather Posted July 16, 2010 Posted July 16, 2010 Too far from origin. solidhist AutoCAD is a antiquated program for 3D solid modeling.... Quote
