elmasea Posted July 18, 2010 Posted July 18, 2010 # -*- coding: cp1252 -*- """Sample to automate AutoCAD: 1) run an autocad drawing 2) read some drawing data: number of objects in the ModelSpace; the value of an AutoCAD system variable; 2) add to the drawing: point; line; polyline. In this code some examples of access to Autocad objects are presented. We must handle variants used to pass array data in and out of AutoCAD COM. Different variant types are possible using comtypes (this is not true with win32com.client package). This example should be improved especially in the user interface. Who wants to participate? """ import array import comtypes.client #Get running instance of the AutoCAD application acad = comtypes.client.GetActiveObject("AutoCAD.Application") # Document object doc = acad.ActiveDocument # Get the ModelSpace object ms = doc.ModelSpace # Get some useful data DwgName = doc.Name # File name count = ms.Count # Number of items in modelspace # Get a variable name sysVarName = 'DWGPREFIX' # directory of the drawing varData = doc.GetVariable(sysVarName) # view in Idle print 'File: ', DwgName print 'N. Items: ', count # >>>> In ModelSpace: # Add a POINT object # Sets the value of an AutoCAD system variable. # PDMODE and PDSIZE system variables control the appearance of point objects sysVarName = "PDMODE" # specifies a Point shape doc.SetVariable(sysVarName,3) # code 3 for X shape sysVarName = "PDSIZE" # controls the size of the point doc.SetVariable(sysVarName,3) # absolute size (3 units half height of icon point) pt = array.array('d', [0,0,0]) # to convert in variant point = ms.AddPoint(pt) # Add a LINE pt1 = array.array('d', [0.0,0.0,0]) # start point pt2 = array.array('d', [20.0,20.0,0]) # end point line = ms.AddLine(pt1, pt2) # Add a POLYLINE # We assign the vertices ptl = [] pt = [20.0,20.0,0] ptl = ptl + pt pt = [40.0,30.0,0] ptl = ptl + pt pt = [70.0,40.0,0] ptl = ptl + pt ptlst = array.array('d', ptl) pline = ms.AddPolyline(ptlst) # Select an item # The user selects an object (the polyline) by picking a point on the screen returnObj = doc.Utility.GetEntity("Select Object:") """Each entity in autocad has a unique value. Ex. for a line object the ObjectName is AcDbLine and the EntityType value is 19 """ # common code for line, polyline print 'DXF entity name: ', returnObj[0].EntityName # it is the class name of the object print returnObj[0].EntityType # the type of entity print returnObj[0].Layer print returnObj[0].Length # only polyline retCoord = returnObj[0].Coordinates num_vertex = len(retCoord)/3 for i in range(num_vertex): print returnObj[0].Coordinate(i) print ">>>>>>>>>>" >>>>>>>>>>>>>> Quote
