Hi all, I'm new to this forum and to AutoLISP programming.
I've studied a tutorial and now I'm trying to do something by myself.
I have a 2D drawing with a square made using a polyline, now I want to create a routine which asks me to select a polyline and simply tells me that I have selected it correctly.
This is my code
(defun c:polysel(/ ent_name element)
 (setq ent_name (car(entsel "\n Select a polyline:")))
 (setq element (entget ent_name))
 (if (= (cdr(assoc 0 element)) "POLYLINE")
   (print "\n Polyline selected!")
I select the polyline, but the message "Polyline selected!" doesn't appear, what's wrong?
Chech this out;
(defun c:polysel (/ ent_name element)
   (alert " Your have selected POLYLINEs.")
   (alert (strcat "Your Selection is .." " "(cdr (assoc 0 element))"."))
Welcome to CADTutor
Tharwat
Thanks, it says I have selected a LWPolyline, so I suppose I have to check for LWPolyline and not POLYLINE since I'm working on 2D drawings.
Yes try to select any other entity, so it will give you the name of the selected entity....
Regards
Tharwat
Welcome to the forum!
Just a slightly different test expression from your code Alhazred
(if
   (wcmatch (setq etype (cdr(assoc 0 element))) "*POLYLINE")
   (princ (strcat  "\n[" etype "] selected"))
