Hi , I am new to acad.
Ik have made a drawing of a triangle.
base line = A,B
Top = M
distans between A and B stays the same.
I would like to display a angle between the lines AM and BM.
This angle has to display a changing angle , when i move point M...
So: A and B stay as they are but i need to move point M until i get a specific angle , so i need to see the angle as i move point M?
How do i do this?
I checked the angle every time i have moved point M by using the INQUIRY/ANLGE menu but this is to much work...
As i mentioned before ... I'm new:cry:
dagger38
Draw the angle dimension at M. Then by picking the two lines and the dimension, and making the grip at M and the dimension active, you can drag M all over the place and the angle dimension will up date.
Alternatively, if you know what the angle should be at M, you could construct the triangle. :D
ok thats wat i am looking for... The point is , i dont know how to make the angle display on the drawing???
dagger38
You need to learn about dimensioning, and I think it would be better if you do a bit of exploring in that direction.
What you need to look out for is to format a dimension style, then to draw angular dimensions. :)
got it!:shock:
command :dimangular
shoos line1 line 2 and presto angle displayed!:D
Thanks (now for making the displayed tekst bigger):oops:
Dimscale and/or Dimtxt
Be sure the text style you are using in your dimension style has a fixed height of 0.
