monk Posted July 20, 2010 Posted July 20, 2010 Hello I'm making a new title block which im setting up as a dynamic block etc. My current problem: 1. I want it to have visibility option to change size A0,A1,A2,A3 - This is fine i can manage this! 2. I also have plot stamps which are construction issue, tender issue, preliminary etc I would like these to be like a visibility option where you can switch between them. You cant have 2 visibility options, i found this http://www.private.peterlink.ru/poleshchuk/cad/2009/tainypod12e.htm But in 2011 struggle to get it to work. Any ideas?? Quote
monk Posted July 20, 2010 Author Posted July 20, 2010 After some research success! Using normal linear strech parameters with a lookup table, and then a visibility state for the plot stamps. Will post when im done Quote
monk Posted July 21, 2010 Author Posted July 21, 2010 Still tweaking, any suggestions welcome but someone may find this useful. Texts on a seperate layer to allow easy font change/colours etc. TitleBlock.dwg Quote
reccakeys Posted July 22, 2010 Posted July 22, 2010 All of you here are elite. I don't have any idea what the topic means. I am a newbie here. I am very willing to learn new things. Hope you accept me here.. Thanks in advance Quote
HLC Posted September 15, 2025 Posted September 15, 2025 You can't use two visibility parameters in the same dynamic block. — What if I want to switch between dimensions and versions? — The most common approach is to create a combined visibility state, such as "A1 - Bidding Version" or "A1 - Construction Version." — Does that sound like more states to manage? — Yes, it's more cumbersome, but this is a limitation of AutoCAD dynamic blocks. If you want more flexibility, consider using a lookup table or attribute field. Quote
