Autocad 2009 --hatch
how do I make a new hatch pattern?? or is it downloadable?
I am having problems in adjusting the scale when I use hatch...
Do a search of this site. The topic of creating new hatch patterns has been discussed previously.
There are a number of websites where free hatch patterns can be downloaded.
The patterns can either be added to acad.pat (usually not a good idea) or be contained in a new .pat file. Make sure that if you create a new .pat file that you tell AutoCAD the "path" to the file under Tools > Options > Files.
What type of problems are you having adjusting the scale of a pattern?
I want it to appear smaller ... but I already adjusted the scale ..still nothing happened.:(
Can you post an image?
What hatch pattern are you using?
What scale are you using?
Will you be plotting from a layout or from model space?
Thank you very much for the links !!! :D
