waybay Posted July 21, 2010 Posted July 21, 2010 I have a hdri image (hdr. file) I want to use as an environment, what do I need to convert the file to use i photoview 360 and how? Can i also do the same in photoworks? Quote
shift1313 Posted July 21, 2010 Posted July 21, 2010 Which version of Solidworks do you have? I dont know that you can use the image in Photoview 360 but you can certainly create your own environment in Photoworks withing the SW program. From the Photoworks drop down you select Scene. In the scene Editor window you have a Room and a Back/Foreground tab as well as Environment. Take a look through those 3 tabs and see what your options are. The scene images in SW are laid out pretty well and the Environment files are .hdr. Most of the environments use spherical mapping but depending on your image you can do cubic and planar. Quote
