VBA CODE ERROR / New collection problem..
hello..
I am using "autocad2006".
I want to know the number of lines and length of lines drawn at "current layer".
But it didn't work properly. I don't know why.
Please help me about below code.
Sub LineSelect()
Dim mode As Integer
Dim retval As New Collection
Dim gpCode(0) As Integer
Dim dataValue(0) As Variant
Dim ssetObj As AcadSelectionSet
Dim tempent As AcadEntity
With ThisDrawing
gpCode(0) = 0: dataValue(0) = "LINE"
mode = acSelectionSetAll
On Error Resume Next
If .SelectionSets("SELECT") Then .SelectionSets("SELECT").Delete
On Error GoTo 0
Set ssetObj = .SelectionSets.Add("SELECT")
ssetObj.Select mode, , , gpCode, dataValue
Dim idBlock As Long
idBlock = ThisDrawing.ActiveLayout.Block.ObjectID
Dim i As Integer
For i = 0 To ssetObj.Count - 1
If ssetObj(i).OwnerID = idBlock Then
retval.Add tempent
End If
Next i
MsgBox retval.Count 'number of lines at current layout
Dim Eac As AcadLine
For Each Eac In retval
MsgBox Eac.Length 'ERROR
Next Eac
End With
End Sub
thank you
I think the problem is that “tempent” in this line has never been set to a value.
retval.Add tempent
SEANT
I think so.. I will try again.
thank you..
