Perfect example of what I'm looking for is: if you type in -insert it will remember the last block you've inserted and if you hit enter the routine continues with that block.
I can't figure it out :oops:
(defun c:test (/)
 (setq prmpt (getstring (strcat "\nWhat would you like to say? <" prmpt "> : ")))
 (alert prmpt)
Edited by Lt Dan's legs
I think that this is what you are looking for (take care that a neutral answer - - for GETSTRING function is an empty string):
(defun c:test ( / LastUsed ToUse )
(setq LastUsed "LastUsedBlock")                 ;name of last used block
;test is user answer by string or by <ENTER>
(if (= (setq ToUse (getstring (strcat "\nWhat would you like to say? <" LastUsed "> : "))) "")
 (setq ToUse LastUsed)                          ;use default value
(alert ToUse)
Regards,
PS. I’m afraid that thread’s title is not appropriate for your request…
You might want to look into the sysvar "INSNAME". -David
When I started this thread I was looking at a routine lee mac made for me. counting routine
Maybe that's why I wasn't getting my result! :oops:
Thank you for the response. I'll check this in a few minutes
actually this is what I was looking for. Just needed to take my eyes off it for a while and look back
(defun c:test (/ p prmpt)
 (if (NOT (setq p prmpt))
   (SETQ P "\NTESTING"))
 (setq prmpt (getstring (strcat "\nWhat would you like to say? <" p "> : ")))
 (if (eq "" prmpt)
   (setq prmpt p))
 (alert prmpt)
Let me reword that because it sounds like I'm blaming Lee for my problem..
I was looking at a LISP that Lee wrote and it had to do with numbering. I was looking at the wrong part of the routine to manipulate it. Thats why my title is itoa.
Sorry Lee
Sorry Lee
No worries man :)
Another way to code it (I don't like the empty string return of getstring :( )
(defun c:test ( / tmp )
 (alert
   (setq *x*
     (cond
         (eq ""
           (setq tmp
             (getstring t
               (strcat "\nAlert with <"
                 (setq *x*
                   (cond ( *x* ) ( "LeeMac" ))
        *x*
       ( tmp )
