Greendamo Posted July 25, 2010 Posted July 25, 2010 Hi. I use autocad 2009 to design 3D timber handrail all being curly with volutes, transitions etc. The problem im having is that i start by projecting lines up from a 2D plan and joining the tops of the lines with lines. I then fillit the lines where i need to make bends. I then want to be able to turn all of these 3D lines and arcs in to a single spline but i carnt work out how!! PEdit dont work to try and spline them. Any help would be great Thanks Damian Quote
JD Mather Posted July 26, 2010 Posted July 26, 2010 Please any help?? You might try a modern 3D CAD program like Autodesk Inventor. Quote
