hi all..
i had troublewith this drawing i had..:?
i need to delete this text...
e problem is i cant even click on it..:x
i tried to click on other objects or text... well everything is ok.. except for this text & a few object..
so i tried to off all layers except "defpoints". e good thing is.. the text is still there.. so i tried to click on it.. using alot of ways.. still.. i failed! :cry:
ok so i also tried to explode.. well its just not working... :geek:
i try to delete other objects in other layers all went fine... except for this "text" in defpoints layer...
things i've tried..:unsure:
- delete all layer then purge n delete the text >>> NOT WORKING
- note: it isnt locked or freezed!!
help!!:cry:
Is Layer 0 Frozen? If so, Thaw it and then you will be able to select the text.
:) I've unfreeze dat too...
still unable to work...:(
Try to select the text via the QSELECT feature (object: Text, Properties: Layer, Value: Defpoints) and see if that works,
cad64 - i dun hv any idea why im not able to upload any dwg!!:unsure:
tiger - thnx!! deleted it peacefully!! :shock:
Well, I'm glad to hear you got the text deleted, but I would still like to know why you could not select it?
Oh well, problem solved. On to the next. :)
I have run into this on a number of occasions, usually Viewports that can't be selected manually but QSelect works. I have never been able to figure out why. When I run into this problem again, I'll email you the file :D
Tinker - could just be that your file is too big.
  • 4 months later...
Thank you so much you don't understand how long i have been looking for this solution. You are a LEGEND!!!!
  • 13 years later...
Hi, I also wanted to ask about this topic since it is related to my current issue. Why can't I click and edit the text? I tried everything that I could such as using the DBLCKEDIT & PICKFIRST commands. I just can use the QSELECT to delete the text, but not to click or edit it. Can you help me ?
Which text are you unable to edit?
A lot of the "text" in that drawing is geometry, you need to run PDFSHXTEXT to hopefully make it text.
The actual mtext edits just fine for me.
All of the text in this box and also in the title block.😔
You need to go through all sysvars related to text/mtext and double check what editor you have set as well. Start with MTEXTTOOLBAR setting, I believe it defaults to using the ribbon to edit text.
https://cadprotips.com/2017/10/08/multiline-text-and-system-variables-in-autocad/
Could be some issue with your AutoCAD install and/or profile or even a bug with AutoCAD 2025, but run through all the related sysvars first.
I will try to do so. Will update you the outcome later. Thank you!!
