gpd Posted July 27, 2010 Posted July 27, 2010 Hi All Is it possible to select entities in by providing their HANDLE value to ssget or any other function. I have tried but result is nil. Command: (setq han(vla-get-handle(vlax-ename->vla-object(car(entsel))))) Select object: "B9" Command: (setq ss(ssget "X" (list (cons 5 han)))) nil Thanks Quote
Lee Mac Posted July 27, 2010 Posted July 27, 2010 Alternatively, (vla-HandletoObject (vla-get-ActiveDocument (vlax-get-acad-object) ) <handle> ) Should you want the VLA Object... Quote
Se7en Posted July 27, 2010 Posted July 27, 2010 Alternatively, (vla-HandletoObject (vla-get-ActiveDocument (vlax-get-acad-object) ) <handle> ) Should you want the VLA Object... (defun c:Test ( / ent-selected enthandle objHandle ) (setq ent-selected (car (entsel)) enthandle (cdr (assoc 5 (entget ent-selected))) objHandle (vla-get-handle (vlax-ename->vla-object ent-selected)) ) (entdel (handent enthandle)) ;; del the item (redraw) ;;; ;;; This would toss a nasty if used here.. ;;; ;;; (vla-HandletoObject ;;; (vla-get-ActiveDocument ;;; (vlax-get-acad-object) ;;; ) ;;; objHandle ;;; ) (entdel (handent enthandle)) ;; un-del the item (redraw) ;;; Now we can select the items ;;; (vla-HandletoObject (vla-get-ActiveDocument (vlax-get-acad-object) ) objHandle ) ) Quote
iTijn Posted August 10, 2010 Posted August 10, 2010 Hi All, I want to do the same thing, but unfortunately haven't found the answer yet. As fillet isn't easilly programmed I want to 'abuse' the commandline to do it. Example: (Yes I still use VBA) Sub Test4() Dim Commandstring As String Commandstring = "(command ""_fillet"" ""_p"" pause) " ThisDrawing.SendCommand (Commandstring) End Sub Now I would like to replace the "pause" with something that selects the polyline by handle. Is that possible? Thanks Quote
