unlock all layers
marmo
  • Replies 32
  • Se7en
    7
  • alanjt
    5
  • marmo
    5
  • gile
    4
taking pieces of code from the internet without understanding how they work is simplistic.
Marco
And taking them without a simple 'thank you' is disrespectful.
Hi,:)
for a simple 'thank you' see post n°13. :ouch: I'm kidding...
Now i'm going to study lisp:sweat:. I'm serious...
Marco
Hello,:shock:
I read the post quickly:P, I took the code that works and I thank those who posted:D.
Greetings all,
Marco
Nice.:glare:
*lamo*
So you have no intention to learn? John obviously put a lot of time into his answer to benefit your learning, surely the least you could do was study his code.
its cool. I get that a lot because i dont give people the answer outright. I try to teach not give code away.
  • 2 years later...
Hi,
Is there a variable of this I can have and put into my acad pgp to unlock all layers upon open? Have a colleague who uses locked layers as layer off and doesn't respect layer locking. :x
cheers
Hi,
cheers
You can't put the code in your pgp file (not what it's for), but you can put a bit of code in your startup file (acaddoc.lsp, etc.). Remark has posted a nice link to what you need.
  • 7 months later...
to unlock all layers in one click. Not one layer at a time but ALL LAYERS AT ONCE.
1. open the layer properties table or type LAYER. then enter
2. inside the layer properties table, highlight all the layers OR click on one layer and press CTRL A to highlight all at once.
3. then click on one unlock icon AND EVERYTHING UNLOCKS
works for LOCK, FREEZE and LAYER ON.
Good Luck.
  • 2 years later...
  • 1 year later...
How to run this lisp without the ()?
example:
c:unlockall instead of (gc:LayerUnLockAll T)
c:lockprevious instead of (gc:LayerUnLockAll nil)
Hi,
Here's a method using defun-q to store the unlocked layers list within the function so that they can be relocked by calling the same function.
Using
(gc:LayerUnLockAll T) unlock all locked layers and store them in a list within the function
(gc:LayerUnLockAll nil) relock previously unlocked layers stored in the function.
;;; gc:LayerUnLockAll (gile)
;;; Unlock all layers or relock prevously locked layers
;;; Argument : T or nil
;;; Using :
;;; (gc:LayerUnLockAll T) unlock all locked layers
;;; (gc:LayerUnLockAll nil) relock previously unlocked layers
(vl-load-com)
(defun-q
 gc:layerunlockall
 (flag / lst lay)
 (setq lst nil)
 (if flag
   (vlax-for l (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object)))
     (and (= (vla-get-Lock l) :vlax-true)
      (setq lst (cons l lst))
      (vla-put-Lock l :vlax-false)
     (foreach n lst
   (vl-catch-all-apply 'vla-put-Lock (list n :vlax-true))
     (setq lst nil)
 (setq    gc:layerunlockall
    (cons (car gc:layerunlockall)
          (cons (list 'setq 'lst (list 'quote lst))
            (cddr gc:layerunlockall)
 lst
Hi,
You can simply do:
(defun c:unlockall () (gc:layerunlockall T) (princ))
(defun c:lockprevious () (gc:layerunlockall nil) (princ))
Thanks gile :)
Hi,
You can simply do:
