marmo Posted July 29, 2010 Author Posted July 29, 2010 taking pieces of code from the internet without understanding how they work is simplistic. Marco Quote
alanjt Posted July 30, 2010 Posted July 30, 2010 taking pieces of code from the internet without understanding how they work is simplistic.Marco And taking them without a simple 'thank you' is disrespectful. Quote
marmo Posted July 30, 2010 Author Posted July 30, 2010 Hi, for a simple 'thank you' see post n°13. I'm kidding... Now i'm going to study lisp:sweat:. I'm serious... :) Marco Quote
Se7en Posted July 30, 2010 Posted July 30, 2010 Hello,I read the post quickly:P, I took the code that works and I thank those who posted:D. Greetings all, Marco Nice. *lamo* ............. Quote
Se7en Posted July 30, 2010 Posted July 30, 2010 So you have no intention to learn? John obviously put a lot of time into his answer to benefit your learning, surely the least you could do was study his code. its cool. I get that a lot because i dont give people the answer outright. I try to teach not give code away. Quote
mostlynice Posted June 18, 2013 Posted June 18, 2013 Hi, Is there a variable of this I can have and put into my acad pgp to unlock all layers upon open? Have a colleague who uses locked layers as layer off and doesn't respect layer locking. cheers Quote
ReMark Posted June 18, 2013 Posted June 18, 2013 Wouldn't it be better, if there was a variable, to use it in a snippet of lisp and put this in one's acaddoc.lsp file? You can find at least three ways to unlock all layers in this thread... http://www.cadtutor.net/forum/showthread.php?50859-unlock-all-layers Quote
alanjt Posted June 18, 2013 Posted June 18, 2013 Hi, Is there a variable of this I can have and put into my acad pgp to unlock all layers upon open? Have a colleague who uses locked layers as layer off and doesn't respect layer locking. cheers You can't put the code in your pgp file (not what it's for), but you can put a bit of code in your startup file (acaddoc.lsp, etc.). Remark has posted a nice link to what you need. Quote
segunopadeji Posted February 18, 2014 Posted February 18, 2014 to unlock all layers in one click. Not one layer at a time but ALL LAYERS AT ONCE. 1. open the layer properties table or type LAYER. then enter 2. inside the layer properties table, highlight all the layers OR click on one layer and press CTRL A to highlight all at once. 3. then click on one unlock icon AND EVERYTHING UNLOCKS works for LOCK, FREEZE and LAYER ON. Good Luck. Quote
Happy Hobbit Posted March 9, 2016 Posted March 9, 2016 Old post I know but wouldn't simply (command "-layer" "U" "*" "") do it? Quote
tive29 Posted May 23, 2017 Posted May 23, 2017 How to run this lisp without the ()? example: c:unlockall instead of (gc:LayerUnLockAll T) c:lockprevious instead of (gc:LayerUnLockAll nil) Hi, Here's a method using defun-q to store the unlocked layers list within the function so that they can be relocked by calling the same function. Using (gc:LayerUnLockAll T) unlock all locked layers and store them in a list within the function (gc:LayerUnLockAll nil) relock previously unlocked layers stored in the function. ;;; gc:LayerUnLockAll (gile) ;;; Unlock all layers or relock prevously locked layers ;;; ;;; Argument : T or nil ;;; ;;; Using : ;;; (gc:LayerUnLockAll T) unlock all locked layers ;;; (gc:LayerUnLockAll nil) relock previously unlocked layers (vl-load-com) (defun-q gc:layerunlockall (flag / lst lay) (setq lst nil) (if flag (vlax-for l (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))) (and (= (vla-get-Lock l) :vlax-true) (setq lst (cons l lst)) (vla-put-Lock l :vlax-false) ) ) (progn (foreach n lst (vl-catch-all-apply 'vla-put-Lock (list n :vlax-true)) ) (setq lst nil) ) ) (setq gc:layerunlockall (cons (car gc:layerunlockall) (cons (list 'setq 'lst (list 'quote lst)) (cddr gc:layerunlockall) ) ) ) lst ) Quote
gile Posted May 23, 2017 Posted May 23, 2017 Hi, You can simply do: (defun c:unlockall () (gc:layerunlockall T) (princ)) (defun c:lockprevious () (gc:layerunlockall nil) (princ)) Quote
tive29 Posted May 24, 2017 Posted May 24, 2017 Thanks gile Hi, You can simply do: (defun c:unlockall () (gc:layerunlockall T) (princ)) (defun c:lockprevious () (gc:layerunlockall nil) (princ)) Quote
