halfcracked Posted September 8, 2008 Posted September 8, 2008 Is there a limit to the # of dashes you can use in a hatch line? I'm trying to setup a hatch for a 3hr wall that has 3 small dashes separated by a long dash. but it keeps crashing AutoCAD. But before it hits the desktop the text box comes saying something about too many definitions. This works fine: *SA_2HR,HATCH FOR 2HR WALLS 0, 0,0, 0,.25, 1.5,-.4,.5,-.4,.5,-.4 This crashes: *SA_3HR,HATCH FOR 3HR WALLS 0, 0,0, 0,.25, 1.5,-.4,.5,-.4,.5,-.4,.5,-.4 Any thoughts? Quote
ReMark Posted September 8, 2008 Posted September 8, 2008 I don't believe so. Somewhere around here I have a linetype with four small dashes. Now, what the heck did I call it? Quote
rkmcswain Posted September 8, 2008 Posted September 8, 2008 Is there a limit to the # of dashes you can use in a hatch line? If you mean linetype, then yes there is a limit of 12. This is documented in the customization guide. Quote
eldon Posted September 8, 2008 Posted September 8, 2008 I found this in the customization file and would explain why your second line-type crashes. Patterns with Dashed Lines [AutoCAD Customization Guide: ACG] To define dashed line patterns, you append dash-length items to the end of the line definition item. Each dash-length item specifies the length of a segment making up the line. If the length is positive, a pen-down segment will be drawn. If the length is negative, the segment is pen-up, and it won't be drawn. The pattern starts at the origin point with the first segment, and cycles through the segments in circular fashion. A dash length of 0 draws a dot. You can specify up to six dash lengths per pattern line. However, rkmcswain says 12, so I am confused I reckon you had better look in your help files under "Patterns with Dashed Lines" and see which applies to you. Quote
halfcracked Posted September 8, 2008 Author Posted September 8, 2008 This is for a HATCH definition So I make it 8 (see my code) which should be under the 12 limit but over 6. Unfortunately the text window pops under some toolbars & the program CTD before I can make out more than a word or two of the error text. Here's the series of hatches I have: *SA_1HR,HATCH FOR 1HR WALLS 0, 0,0, 0,.25, 1.5,-.4,.5,-.4 *SA_2HR,HATCH FOR 2HR WALLS 0, 0,0, 0,.25, 1.5,-.4,.5,-.4,.5,-.4 *SA_3HR,HATCH FOR 3HR WALLS 0, 0,0, 0,.25, 1.5,-.4,.5,-.4,.5,-.4,.5,-.4 you can see it's a progression of adding a dash to each hatch the 1 & 2 hr hatch work fine the 3hr crashes AutoCAD. Hrmmm maybe I'll have to define it as 2 lines overtop eachother. Quote
eldon Posted September 8, 2008 Posted September 8, 2008 Here's the series of hatches I have: *SA_1HR,HATCH FOR 1HR WALLS 0, 0,0, 0,.25, 1.5, -.4, .5, -.4 *SA_2HR,HATCH FOR 2HR WALLS 0, 0,0, 0,.25, 1.5, -.4, .5, -.4, .5, -.4 *SA_3HR,HATCH FOR 3HR WALLS 0, 0,0, 0,.25, 1.5, -.4, .5, -.4, .5, -.4, .5, -.4 I am not sure if you are counting the dashes correctly - the 1Hr hatch has 4 dashes, the 2hr hatch has 6 dashes and the 3hr hatch has 8 dashes which crashes AutoCAD Quote
rkmcswain Posted September 8, 2008 Posted September 8, 2008 However, rkmcswain says 12, so I am confused I didn't say it, Autodesk did... :wink: "You can enter up to 12 dash-length specifications per linetype..." Quote
halfcracked Posted September 8, 2008 Author Posted September 8, 2008 Yeah it's 8 which is over the limit of 6 for hatches. Odd that lines can have 12 but hatches only 6. Here's my work around: *SA_3HR,HATCH FOR 3HR WALLS 0, 0,0, 0,.25, 1.5,-3.1 0, 1.9,0, 0,.25,.5,-.4,.5,-.4,.5,-2.3 Quote
eldon Posted September 8, 2008 Posted September 8, 2008 I didn't say it, Autodesk did... :wink: Ah - sorted. We were both correct. You were talking about linetypes and I was talking about hatch patterns. Quote
eldon Posted September 9, 2008 Posted September 9, 2008 Of course another way to approach the problem would be to hatch and THEN change the linestyle of the hatch. That way you could have your 12 dashes in your linestyle Quote
