VisDak Posted July 28, 2010 Posted July 28, 2010 Good day to all, i just toggle an LSP that insert a dynamic block and stretch automatically on its point direction, http://www.cadtutor.net/forum/showthread.php?47619-Lisp-amp-Dynamic-Block/page5 but i created a dyn block that stretch Y distance and X distance its not fuctioning the stretch on the LSP, is it possible to be create an LSP that X and Y distances to be stretch diagonally, 2 points will be activate in route, first point is to specify the desire point location and the second point will be diagoanl direction to the corner of rectangle, please check the image for clearly illustration, i also attach the Dynamic block.dwg as a sample. hopefully you could help me Thanks in advance SLAB_OPENING_BLOCKS.dwg Quote
Tharwat Posted July 29, 2010 Posted July 29, 2010 The dynamic block could be stretched diagonally in X and Y as well. so no need for a Lisp to stretch it since Autocad could handle it easily . Regards Tharwat Quote
