lisp to calculate mass
dear friends
i need a lisp which can calculate mass of a 3d solid
input=density and 3d solid object
output= mass
  • Replies 24
  • Lee Mac
    5
  • naserrishehri@yahoo.com
    3
  • dpenney
    3
  • xces
    3
This can get you started:
(if (vlax-property-available-p MyVLAEntity "VOLUME")
(vlax-get (vlax-ename->vla-object MyVLAEntity) "VOLUME")
Regards,
dear froend
please explain more about your code.how can i use it?
kind regards
That code will return the volume in current units of a VLA entity - it is intended to be added to your already writhed code.
Regards,
Is this what you wanted?
;by Small Fish
(defun c:Solid_Prop(/ OldCmd PDen enaPline vname SolidVol SolidWgt)
   (vl-load-com);load vla
   (setq   OldCmd (getvar "CMDDIA"))
   (setvar "CMDECHO" 0)
   (setq PDen (getreal "\nDensity of object : ")
         enaPline(car(entsel"\nSelect any edge of solid object : "))
         vname (vlax-ename->vla-object enaPline )
         SolidVol (/(vla-get-volume vname)1e9);volume
         SolidWgt (* SolidVol  PDen );weight
   );setq
   (alert
   (strcat
       "Properties for a solid object at "
       (rtos PDen 2 2)" t/m³ : "
       "\n"
       "\nVolume = "
       (setq VolTxt (rtos SolidVol 2 2))
        " m³"
       "\t\tWeight = "
              (setq WgtTxt (rtos SolidWgt 2 2))
       " t"
   );strcat
   );alert
   (setvar "CMDECHO" OldCmd);
   );defun
dear friend
thanks a lot for your help.
kind regards
  • 4 years later...
;by Small Fish
   );setq
   (alert
   (strcat
       "\n"
       "\nVolume = "
        " m³"
       "\t\tWeight = "
       " t"
   );strcat
   );alert
   );defun
What would change to give answers of kg/m3
MASSPROP just give it a try its possible to retrive the properties by writing to file then re-reading.
Yes MASSPROP write it to the file. But how can absorb that coordinates to lisp
  • 1 year later...
;by Small Fish
   );setq
   (alert
   (strcat
       "\n"
       "\nVolume = "
        " m³"
       "\t\tWeight = "
       " t"
   );strcat
   );alert
   );defun
This is awesome.
Could you possibly expand this so that after the program is run for the first time, the density doesn't have to be input every time. Something like the offset comand which remembers the last input.
I'm trying to set up a prompt using your code which would give something like this:
Select any edge of solid object or [[b][size="4"]D[/size][/b]ensity] <7850.00>:
7850.00 being for example the value that was input the previous time.
Try the following instead:
([color=BLUE]defun[/color] c:sp ( [color=BLUE]/[/color] den key obj sel )
   ([color=BLUE]setq[/color] key [color=MAROON]"LMac\\solprop-density"[/color])
   ([color=BLUE]if[/color] ([color=BLUE]or[/color] ([color=BLUE]setq[/color] den (getdensity key))
           ([color=BLUE]setq[/color] den (setdensity key))
       ([color=BLUE]while[/color]
           ([color=BLUE]progn[/color]
               ([color=BLUE]setvar[/color] 'errno 0)
               ([color=BLUE]initget[/color] [color=MAROON]"Density Exit"[/color])
               ([color=BLUE]princ[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nCurrent density: "[/color] ([color=BLUE]rtos[/color] den 2)))
               ([color=BLUE]setq[/color] sel ([color=BLUE]entsel[/color] [color=MAROON]"\nSelect edge of solid object [Density/Exit]: "[/color]))
               ([color=BLUE]cond[/color]
                   (   ([color=BLUE]=[/color] 7 ([color=BLUE]getvar[/color] 'errno))
                       ([color=BLUE]princ[/color] [color=MAROON]"\nMissed, try again."[/color])
                   (   ([color=BLUE]or[/color] ([color=BLUE]null[/color] sel) ([color=BLUE]=[/color] [color=MAROON]"Exit"[/color] sel))
                       [color=BLUE]nil[/color]
                   (   ([color=BLUE]=[/color] [color=MAROON]"Density"[/color] sel)
                   (   ([color=BLUE]not[/color] ([color=BLUE]vlax-property-available-p[/color] ([color=BLUE]setq[/color] obj ([color=BLUE]vlax-ename->vla-object[/color] ([color=BLUE]car[/color] sel))) 'volume))
                       ([color=BLUE]princ[/color] [color=MAROON]"\nSelected object does not have Volume property."[/color])
                   (   ([color=BLUE]alert[/color]
                               [color=MAROON]"Properties for a solid object at "[/color]  ([color=BLUE]rtos[/color] den 2 2) [color=MAROON]" t/m³ : \n\n"[/color]
                               [color=MAROON]"Volume = "[/color] ([color=BLUE]rtos[/color] ([color=BLUE]/[/color] ([color=BLUE]vla-get-volume[/color] obj) 1e9) 2 2) [color=MAROON]" m³\t\t"[/color]
                               [color=MAROON]"Weight = "[/color] ([color=BLUE]rtos[/color] ([color=BLUE]*[/color] den ([color=BLUE]/[/color] ([color=BLUE]vla-get-volume[/color] obj) 1e9)) 2 2) [color=MAROON]" t"[/color]
   ([color=BLUE]princ[/color])
([color=BLUE]defun[/color] getdensity ( key [color=BLUE]/[/color] den )
   ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]setq[/color] den ([color=BLUE]getenv[/color] key))
            ([color=BLUE]setq[/color] den ([color=BLUE]distof[/color] den 2))
            ([color=BLUE]<[/color] 0  den)
       den
([color=BLUE]defun[/color] setdensity ( key [color=BLUE]/[/color] def tmp )
   ([color=BLUE]initget[/color] 6)
   ([color=BLUE]if[/color] ([color=BLUE]setq[/color] def (getdensity key)
             tmp ([color=BLUE]cond[/color] (([color=BLUE]getreal[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nSpecify density"[/color] ([color=BLUE]if[/color] def ([color=BLUE]strcat[/color] [color=MAROON]" <"[/color] ([color=BLUE]rtos[/color] def 2) [color=MAROON]">: "[/color]) [color=MAROON]": "[/color])))) (def))
       ([color=BLUE]setenv[/color] key ([color=BLUE]rtos[/color] tmp 2))
   tmp
([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color])
       den
   tmp
Hi,
As per my original question, what would have to change to have the units as kg/m3 - instead of t/m3?
Also, can multiple items be picked or are we just tied to pick individual entities?
It would be really great if we could window and select multiple items with the same density in one go - such as a bolt, nut and washer assemblies for example, etc.
Cheers.
Hi,
Cheers.
+1 , Hello , Lee, Can modify to Density unit: kg/m³ , Output mass unit :kg ?
As you have done 118 posts you should be able to work out how to adjust the lisp for Kg/m3
Its all in these 3 lines the density is 1000 ?
[color=#800000]"Properties for a solid object at "[/color]  ([color=blue]rtos[/color] den 2 2) [color=maroon]" t/m³ : \n\n"[/color]
                               [color=maroon]"Volume = "[/color] ([color=blue]rtos[/color] ([color=blue]/[/color] ([color=blue]vla-get-volume[/color] obj) 1e9) 2 2) [color=maroon]" m³\t\t"[/color]
                               [color=maroon]"Weight = "[/color] ([color=blue]rtos[/color] ([color=blue]*[/color] den ([color=blue]/[/color] ([color=blue]vla-get-volume[/color] obj) 1e9)) 2 2) [color=maroon]" t"[/color]
Since the user is specifying the density value, simply enter a value in kg/m3 (i.e. 1000x larger) and change the t/m3 text accordingly - the calculation will be identical.
Try the following:
([color=BLUE]defun[/color] c:sp ( [color=BLUE]/[/color] den idx key obj sel vol )
               ([color=BLUE]initget[/color] [color=MAROON]"Multiple Density Exit"[/color])
               ([color=BLUE]princ[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nCurrent density: "[/color] ([color=BLUE]rtos[/color] den 2) [color=MAROON]" kg/m³"[/color]))
               ([color=BLUE]setq[/color] sel ([color=BLUE]entsel[/color] [color=MAROON]"\nSelect edge of solid object [Multiple/Density/Exit]: "[/color]))
                   (   ([color=BLUE]=[/color] [color=MAROON]"Multiple"[/color] sel)
                       ([color=BLUE]if[/color] ([color=BLUE]setq[/color] sel ([color=BLUE]ssget[/color] '((0 . [color=MAROON]"3DSOLID"[/color]))))
                           (showdensity den
                               ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] idx ([color=BLUE]sslength[/color] sel))
                                   ([color=BLUE]setq[/color] vol
                                       ([color=BLUE]+[/color]  ([color=BLUE]cond[/color] (vol) (0.0))
                                           ([color=BLUE]vla-get-volume[/color] ([color=BLUE]vlax-ename->vla-object[/color] ([color=BLUE]ssname[/color] sel ([color=BLUE]setq[/color] idx ([color=BLUE]1-[/color] idx)))))
                   (   (showdensity den ([color=BLUE]vla-get-volume[/color] obj)))
([color=BLUE]defun[/color] showdensity ( den vol )
   ([color=BLUE]setq[/color] vol ([color=BLUE]/[/color] vol 1e9))
           [color=MAROON]"Properties for a solid object at "[/color]  ([color=BLUE]rtos[/color] den 2 2) [color=MAROON]" kg/m³ : \n\n"[/color]
           [color=MAROON]"Volume = "[/color] ([color=BLUE]rtos[/color] vol 2 2) [color=MAROON]" m³\t\t"[/color]
           [color=MAROON]"Weight = "[/color] ([color=BLUE]rtos[/color] ([color=BLUE]*[/color] den vol) 2 2) [color=MAROON]" kg"[/color]
       den
             tmp ([color=BLUE]cond[/color] (([color=BLUE]getreal[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nSpecify density (kg/m³)"[/color] ([color=BLUE]if[/color] def ([color=BLUE]strcat[/color] [color=MAROON]" <"[/color] ([color=BLUE]rtos[/color] def 2) [color=MAROON]">: "[/color]) [color=MAROON]": "[/color])))) (def))
   tmp
this is great..
however I was trying to eliminate the message box displaying the results by changing it with print function to display the results in the command line which is more convenient for me but the new function won't break after it does the calculation so it displays the results but still keeps asking me to select new solid(s).
On another note, the meter cubed is not recognized by Acad so i changed it to Unicode \U+00B3
here is a copy so you can test it directly.
Thank you in advance.
(defun c:dmass ( / den idx key obj sel vol )
   (setq key "LMac\\solprop-density")
   (if (or (setq den (getdensity key))
           (setq den (setdensity key))
       (while
               (setvar 'errno 0)
               (initget "Multiple Density Exit")
               (princ (strcat "\nCurrent density: " (rtos den 2) " kg/m\U+00B3"))
               (setq sel (entsel "\nSelect edge of solid object [Multiple/Density/Exit]: "))
               (cond
                   (   (= 7 (getvar 'errno))
                       (princ "\nMissed, try again.")
                   (   (or (null sel) (= "Exit" sel))
                       nil
                   (   (= "Density" sel)
                   (   (= "Multiple" sel)
                       (if (setq sel (ssget '((0 . "3DSOLID"))))
                           (showdensity den
                               (repeat (setq idx (sslength sel))
                                   (setq vol
                                       (+  (cond (vol) (0.0))
                                           (vla-get-volume (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))))
                   (   (not (vlax-property-available-p (setq obj (vlax-ename->vla-object (car sel))) 'volume))
                       (princ "\nSelected object does not have Volume property.")
                   (   (showdensity den (vla-get-volume obj)))
(defun showdensity ( den vol )
   (setq vol (/ vol 1e9))
   (print
       (strcat
           "Properties for a solid object at "  (rtos den 2 2) " kg/m\U+00B3 :"
           "Volume = " (rtos vol 2 2) " m\U+00B3"
           "Weight = " (rtos (* den vol) 2 2) " kg"
(defun getdensity ( key / den )
   (if (and (setq den (getenv key))
            (setq den (distof den 2))
            (< 0  den)
       den
(defun setdensity ( key / def tmp )
   (initget 6)
   (if (setq def (getdensity key)
             tmp (cond ((getreal (strcat "\nSpecify density (kg/m\U+00B3)" (if def (strcat " <" (rtos def 2) ">: ") ": ")))) (def))
       (setenv key (rtos tmp 2))
   tmp
(vl-load-com) (princ)
Change print to prompt and add \n before Properties, Volume & Weight.
