lisp to calculate mass
Since the user is specifying the density value, simply enter a value in kg/m3 (i.e. 1000x larger) and change the t/m3 text accordingly - the calculation will be identical.
Try the following:
([color=BLUE]defun[/color] c:sp ( [color=BLUE]/[/color] den idx key obj sel vol )
   ([color=BLUE]setq[/color] key [color=MAROON]"LMac\\solprop-density"[/color])
   ([color=BLUE]if[/color] ([color=BLUE]or[/color] ([color=BLUE]setq[/color] den (getdensity key))
           ([color=BLUE]setq[/color] den (setdensity key))
       ([color=BLUE]while[/color]
           ([color=BLUE]progn[/color]
               ([color=BLUE]setvar[/color] 'errno 0)
               ([color=BLUE]initget[/color] [color=MAROON]"Multiple Density Exit"[/color])
               ([color=BLUE]princ[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nCurrent density: "[/color] ([color=BLUE]rtos[/color] den 2) [color=MAROON]" kg/m³"[/color]))
               ([color=BLUE]setq[/color] sel ([color=BLUE]entsel[/color] [color=MAROON]"\nSelect edge of solid object [Multiple/Density/Exit]: "[/color]))
               ([color=BLUE]cond[/color]
                   (   ([color=BLUE]=[/color] 7 ([color=BLUE]getvar[/color] 'errno))
                       ([color=BLUE]princ[/color] [color=MAROON]"\nMissed, try again."[/color])
                   (   ([color=BLUE]or[/color] ([color=BLUE]null[/color] sel) ([color=BLUE]=[/color] [color=MAROON]"Exit"[/color] sel))
                       [color=BLUE]nil[/color]
                   (   ([color=BLUE]=[/color] [color=MAROON]"Density"[/color] sel)
                   (   ([color=BLUE]=[/color] [color=MAROON]"Multiple"[/color] sel)
                       ([color=BLUE]if[/color] ([color=BLUE]setq[/color] sel ([color=BLUE]ssget[/color] '((0 . [color=MAROON]"3DSOLID"[/color]))))
                           (showdensity den
                               ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] idx ([color=BLUE]sslength[/color] sel))
                                   ([color=BLUE]setq[/color] vol
                                       ([color=BLUE]+[/color]  ([color=BLUE]cond[/color] (vol) (0.0))
                                           ([color=BLUE]vla-get-volume[/color] ([color=BLUE]vlax-ename->vla-object[/color] ([color=BLUE]ssname[/color] sel ([color=BLUE]setq[/color] idx ([color=BLUE]1-[/color] idx)))))
                   (   ([color=BLUE]not[/color] ([color=BLUE]vlax-property-available-p[/color] ([color=BLUE]setq[/color] obj ([color=BLUE]vlax-ename->vla-object[/color] ([color=BLUE]car[/color] sel))) 'volume))
                       ([color=BLUE]princ[/color] [color=MAROON]"\nSelected object does not have Volume property."[/color])
                   (   (showdensity den ([color=BLUE]vla-get-volume[/color] obj)))
   ([color=BLUE]princ[/color])
([color=BLUE]defun[/color] showdensity ( den vol )
   ([color=BLUE]setq[/color] vol ([color=BLUE]/[/color] vol 1e9))
   ([color=BLUE]alert[/color]
           [color=MAROON]"Properties for a solid object at "[/color]  ([color=BLUE]rtos[/color] den 2 2) [color=MAROON]" kg/m³ : \n\n"[/color]
           [color=MAROON]"Volume = "[/color] ([color=BLUE]rtos[/color] vol 2 2) [color=MAROON]" m³\t\t"[/color]
           [color=MAROON]"Weight = "[/color] ([color=BLUE]rtos[/color] ([color=BLUE]*[/color] den vol) 2 2) [color=MAROON]" kg"[/color]
([color=BLUE]defun[/color] getdensity ( key [color=BLUE]/[/color] den )
   ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]setq[/color] den ([color=BLUE]getenv[/color] key))
            ([color=BLUE]setq[/color] den ([color=BLUE]distof[/color] den 2))
            ([color=BLUE]<[/color] 0  den)
       den
([color=BLUE]defun[/color] setdensity ( key [color=BLUE]/[/color] def tmp )
   ([color=BLUE]initget[/color] 6)
   ([color=BLUE]if[/color] ([color=BLUE]setq[/color] def (getdensity key)
             tmp ([color=BLUE]cond[/color] (([color=BLUE]getreal[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nSpecify density (kg/m³)"[/color] ([color=BLUE]if[/color] def ([color=BLUE]strcat[/color] [color=MAROON]" <"[/color] ([color=BLUE]rtos[/color] def 2) [color=MAROON]">: "[/color]) [color=MAROON]": "[/color])))) (def))
       ([color=BLUE]setenv[/color] key ([color=BLUE]rtos[/color] tmp 2))
   tmp
([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color])
Thanks Lee, :thumbsup:
  • Replies 24
  • Lee Mac
    5
  • naserrishehri@yahoo.com
    3
  • dpenney
    3
  • xces
    3
Try the following:
                           (showdensity den
       den
   tmp
Perfect. Many thanks for your time.
  • 1 year later...
This is great! I've been looking for a lisp to help me generate a table summing the weight of solids sorted by materials/layers using the volume of the items and the layer's description to specify the lb/Lft. Do you think this routine could be modified to do this?
AntAle
Attach a sample file, solids and table. I know something that can help you, but you need to check.
