Select All via Linetype???
I'm writing a custom LISP to grab all entities with a custom LINETYPE and change it to a normal AutoCAD related Linetype. I don't need to use the ENTSEL with a DXF Group Code function because I already know the Linetype name. I think I can just simply use the CHPROP method but it's asking to Select Objects when I use it. I'm just wondering what is the best way for me to use the SETQ function for the Linetype.
Hope this makes sense. Thanks in advance for the help. :)
Hi. Change "DASHED" into custom linetype.
(defun c:cln(/ lSet)
 (if(setq lSet(ssget "_X" '((6 . [color="Blue"]"DASHED"[/color]))))
     (princ(strcat "\n" (itoa(sslength lSet)) " objects found."))
     (sssetfirst nil lSet)
     (initget "Yes No")
     (if(= "Yes"(getkword "\nChange linetype? [Yes/No]: "))
 (command "_.chprop" lSet "" "_lt" "Continuous" "")
 (sssetfirst nil nil)
); end if
     ); end progn
   ); end if
 ); end of c:cln
Oh okay, SSGET is what I'm after. I will try it now... ASMI thanks for the code but I was wanting to learn myself... lol. You spoil me, you know this right? :)
Probably, excuse if it so. But you have many possibilities to write a code by another. Absolutely on another... :)
Maybe to change from HIDDEN to BYLAYER:
(defun c:rlt (/ ss)
 (and (setq ss (ssget "X" (list (cons 6 "HIDDEN"))))
      (command "_.CHANGE" ss "" "_P" "_LT" "BYLAYER" ""))
(prin1))
-David
ASMI, David, worked perfectly. Thanks again guys!! ASMI next time teach me instead of writing a code for me, haha.... :wink:
I was on the right track, I just forgot about using the SSGET function. I know in the DXF Group Codes that 6 is referred to Linetypes. Quick question David, the code in (cons 6 "HIDDEN") is this '6' still associated with Linetypes such as in the DXF Group Codes? Just wondering is all. Thanks again everyone.
StykFacE,
Yes, 6 is linetypes. The VLisp help is actually a pretty good reference.
For a list of all of the numerical codes:
DXF Reference Table Of Contents -> DXF Format -> Group Codes In Numerical Order
-David
