SadisticIron Posted August 2, 2010 Posted August 2, 2010 I am trying to do screen shots for some parts that were drawn up and cut out on my cnc table for Mini Truckn magazine build we are doing, but the editor wants the image of the autocad drawing. We took a picture with a camera but kind of cheesy. Is there a way to do screen shots like I do on the internet and print them? All help will be much appreciated. Thank you:D Quote
Cad64 Posted August 2, 2010 Posted August 2, 2010 Just hit the "Print Screen" button on your keyboard, then paste into Photoshop, or any image editing program. Quote
SadisticIron Posted August 2, 2010 Author Posted August 2, 2010 I knew it was going to be something easy just did not think this easy. Thank you so much for the quick reply. Quote
f700es Posted August 2, 2010 Posted August 2, 2010 and if you need a bit more power and options you can try screenpresso http://www.screenpresso.com/ Quote
MSasu Posted August 2, 2010 Posted August 2, 2010 Also use + if need to capture only the current dialog box, not the entire screen (i.e. for inputs/settings). Regards, Quote
bobsy852 Posted August 3, 2010 Posted August 3, 2010 Also use + if need to capture only the current dialog box, not the entire screen (i.e. for inputs/settings). did not know this little trick! Nice 1! much better than showing everyone what other programmes Im using! Quote
