  • Replies 49
  • Kerry Brown
    27
  • Tharwat
    22
  • Lee Mac
    1
Posted Images
Hello Kerry.
You have done a very hard work for me, I do appreciate that so much.
Most of these codes that you have given are not known to me, so I feel a little bit hard to deal with them.
Thanks
With the code in post #31
We need the results of
(entget (cadr (kdub:MLINESTYLE-GET "Closed") ))
(entget (cadr (kdub:MLINESTYLE-GET "Opened") ))
(entget (cadr (kdub:MLINESTYLE-GET "First-open") ))
(entget (cadr (kdub:MLINESTYLE-GET "Last-open") ))
so I know how you want the styles defined { using entmake }.
Just load the code in Post #31
http://www.cadtutor.net/forum/showthread.php?51057-Set-a-specific-MLine-Style-on&p=346817&viewfull=1#post346817
and then run these and post the results.
I may be able to help you while you study the code.
Here they are ....
First.
Command:[b] (entget (cadr (kdub:MLINESTYLE-GET "Closed") ))[/b]
((-1 . <Entity name: 7ee04600>) (0 . "MLINESTYLE") (5 . "1B0") (102 .
"{ACAD_REACTORS") (330 . <Entity name: 7ee02cb8>) (102 . "}") (330 . <Entity
name: 7ee02cb8>) (100 . "AcDbMlineStyle") (2 . "CLOSED") (70 . 272) (3 . "")
(62 . 256) (51 . 1.5708) (52 . 1.5708) (71 . 2) (49 . 0.5) (62 . 256) (6 .
"BYLAYER") (49 . -0.5) (62 . 256) (6 . "BYLAYER"))
Second.
Command: (entget (cadr (kdub:MLINESTYLE-GET "Opened") ))
((-1 . <Entity name: 7ee04608>) (0 . "MLINESTYLE") (5 . "1B1") (102 .
name: 7ee02cb8>) (100 . "AcDbMlineStyle") (2 . "OPENED") (70 . 0) (3 . "") (62
Third.
Command: (entget (cadr (kdub:MLINESTYLE-GET "First-open") ))
((-1 . <Entity name: 7ee04620>) (0 . "MLINESTYLE") (5 . "1B4") (102 .
name: 7ee02cb8>) (100 . "AcDbMlineStyle") (2 . "FIRST-OPEN") (70 . 256) (3 .
"") (62 . 256) (51 . 1.5708) (52 . 1.5708) (71 . 2) (49 . 0.5) (62 . 256) (6 .
Forth.
Command: (entget (cadr (kdub:MLINESTYLE-GET "Last-open") )) ((-1 . <Entity
name: 7ee04628>) (0 . "MLINESTYLE") (5 . "1B5") (102 . "{ACAD_REACTORS") (330 .
<Entity name: 7ee02cb8>) (102 . "}") (330 . <Entity name: 7ee02cb8>) (100 .
"AcDbMlineStyle") (2 . "LAST-OPEN") (70 . 16) (3 . "") (62 . 256) (51 . 1.5708)
(52 . 1.5708) (71 . 2) (49 . 0.5) (62 . 256) (6 . "BYLAYER") (49 . -0.5) (62 .
Regards.
Here is the correct Lisp that it was written wrong by me before with (if ..... T).
(defun c:du (/ curlay width style)
 (setq curlay (getvar "clayer"))
 (if (not (tblsearch "layer" "ACDUCT"))
   (command "._-layer" "_make" "ACDUCT" "_ltype" "continuous" "" "_color" "142" "" "")
    (setvar 'clayer "acduct")
 (setq width (getint "\nSpecify width of Duct: "))
  (initget "Closed Opened First-open Last-open")
 (if(setq sty (getkword "\nSpecify the MLineSty [Closed Opened First-open Last-open]:"))
        (setvar 'cmlstyle sty)
   (alert "The chosen MLStyle is not avaliable")
   (exit)))
 (command "_mline" "_J" "_z" "_scale" width)
  (command pause)
  (setvar "clayer" curlay)
Have a play with these :
(defun c:du (/ curlay width sty)
 (kdub:AssertMultiLineStyleDefinitionsExist)
 (setq width (getdist "\nSpecify width of Duct: "))
 (initget 1 "Closed Opened First-open Last-open")
 (if (and (setq sty (getkword "\nSpecify the MLineStyle [Closed Opened First-open Last-open]:"))
          (Kdub:Mlinestyle-Get sty)
   (progn (alert "The chosen MLStyle is not avaliable") (exit))
 (command "_mline" "_J" "_z" "_scale" width "")
 (command "_mline")
** Library stuff **
(defun Kdub:Mlinestyle-Get (Name / mlsty-DICT MLSty)
 (if (setq mlsty-DICT (dictsearch (Namedobjdict) "ACAD_MLINESTYLE"))
   (while (and mlsty-DICT
               (not (setq MLSty (if (and (assoc 3 mlsty-DICT) (= (strcase (cdr (assoc 3 mlsty-DICT))) (strcase Name)))
                                  (list (strcase Name) (cdr (cadr (member (assoc 3 mlsty-DICT) mlsty-DICT))))
     (setq mlsty-DICT (cdr (member (assoc 3 mlsty-DICT) mlsty-DICT)))
 MLSty
(defun massoc (key alist / x nlist)
 (foreach x alist
   (if (eq key (car x))
     (setq nlist (cons (cdr x) nlist))
 (reverse nlist)
(defun kdub:AssertMultiLineStyleDefinitionsExist
      (/  mlSty-DICT MultiLineStyle_lst StyleName)
 ;; kdub 20100807
 ;; Ensure definition of AcDbMlineStyles
 ;; Closed Opened First-open Last-open
 (setq mlSty-DICT-ent     (cdr (cadr (member '(3 . "ACAD_MLINESTYLE") (entget (namedobjdict)))))
       MultiLineStyle_lst (mapcar 'STRCASE (massoc 3 (entget mlSty-DICT-ent)))
 dxf 70 Flags (bit-coded):
1 =Fill on
2 = Display miters
16 = Start square end (line) cap
32 = Start inner arcs cap
64 = Start round (outer arcs) cap
256 = End square (line) cap
512 = End inner arcs cap
1024 = End round (outer arcs) cap
 (setq StyleName "Closed")
 (if (not (member (strcase StyleName) MultiLineStyle_lst))
   (dictadd mlSty-DICT-ent
            StyleName
            (entmakex (list '(0 . "MLINESTYLE")
                            '(100 . "AcDbMlineStyle")
                            (cons 2 StyleName)
                            '(70 . 272)                              ; End flag
                            '(3 . "")                                ; StyleDescription
                            '(62 . 256)                              ; fill color
                            '(51 . 1.5708)                           ; start angle
                            '(52 . 1.5708)                           ; end angle
                            '(71 . 2)                                ; qty elements
                            '(49 . 0.5)                              ; element offset
                            '(62 . 256)
                            '(6 . "BYLAYER")                         ; Element Linetype
                            '(49 . -0.5)
                            '(62 . 256)
                            '(6 . "BYLAYER")
 (setq StyleName "Opened")
            StyleName
                            (cons 2 StyleName)
                            '(70 . 0)                                ; End flag
                            '(62 . 256)
                            '(49 . -0.5)
                            '(62 . 256)
                            '(6 . "BYLAYER")
 (setq StyleName "First-open")
            StyleName
                            (cons 2 StyleName)
                            '(70 . 256)                              ; End flag
                            '(62 . 256)
                            '(49 . -0.5)
                            '(62 . 256)
                            '(6 . "BYLAYER")
 (setq StyleName "Last-open")
            StyleName
                            (cons 2 StyleName)
                            '(70 . 16)                               ; End flag
                            '(62 . 256)
                            '(49 . -0.5)
                            '(62 . 256)
                            '(6 . "BYLAYER")
That's Amazing and greatly complete work Mr. Kerry
You did a routine that most of experts couldn't do, all of them saying that it couldn't be
made that way special the ( entmakex Mline ) which is could be trouble maker and may hang up from
time to time.
Thank you so much. your major help is greatly appreciated.
Tharwat
time to time.
FYI, Kerry is entmake'ing an MLineStyle, not an MLine.
I don't know what do you expect from me after that. But my honesty says thank's for paying attention to it.
