gorelli Posted August 4, 2010 Share Posted August 4, 2010 Hi I was wondering how you would draw a hex bolt as the corners have sort of been filleted. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 4, 2010 Share Posted August 4, 2010 Well in AutoCAD (sorry...I don't use Rhino) one would extrude a circle downward from the top of the hex head bolt with a taper of 45 deg. then use the intersect command to come up with the composite shape of the two solids. This will produce the chamfer on the nut you are looking for. Quote Link to comment Share on other sites More sharing options...
