AutoCAD VBA - Object was Erased error when binding xref's
I have the following code to bind all xref's in a drawing. For some reason, I am getting an "Object was erased" error when the blk.bind is attempted. If I manually bind the xref in AutoCAD it works fine.
Private Sub bindXrefs()
   'On Error Resume Next
   'Bind all xrefs (if g.a.) and save
   Set Blocks = ThisDrawing.Blocks
   For Each blk In Blocks
       'Detach unloaded xrefs
       If blk.IsXRef Then
           If blk.Count < 2 Then
               blk.Detach
           Else
               blk.Bind False
           End If
       End If
   Next
End Sub
The code below was probably one of the first things I did with VBA and hasn't been looked at for a good few years now, but as far as I remember it worked fine.
Dim blk As AcadBlock
Count = ThisDrawing.Blocks.Count - 1
While Count >= 0
   Set blk = ThisDrawing.Blocks.Item(Count)
       If blk.IsXRef Then
       blk.Bind False
End If
   Count = Count - 1
Wend
On Error GoTo 0
binderror:
Count = Count
