Hi all,
Having received some really helpful advice about
rotating points to the current view (thanks Gile) I am having some trouble rotating text in the same way.
What I want to do is rotate text en mass from the *top* view to my current view. The problem is rotating the text via the individual insertion points rather than one global rotation point.
Does anyone have any good ideas?
Lownote
depending on your release you should be able to select the text you want and use the properties palette
Hi LeeMac,
We did, due in no small part to your help!
Regards
Lownote
Hi LeeMac,
Regards
Lownote
Excellent - I just wondered why I saw it posted again is all :)
