ulyssey Posted August 9, 2010 Posted August 9, 2010 (edited) Hi! Using vba, I m trying to access to the objects inside a block reference but I don t find how. I select my block with a selection set with a selection set. .ObjectName return : "AcDbBlockReference" but when I tried the GetAttributes(), I got an empty array. I d like to do it without explode the block reference, is that possilble? thanks to help Edited August 9, 2010 by ulyssey Quote
leigh_elkins Posted August 9, 2010 Posted August 9, 2010 can you share a bit more of the code that you have so far please. Quote
