degoos Posted August 10, 2010 Posted August 10, 2010 hi, I would like to use the quick select tool while I select my hatching boundaries, so I don't have to click on every object seperately, can anybody help me please? thx, degoos Quote
ReMark Posted August 10, 2010 Posted August 10, 2010 (edited) What features make your boundaries unique? Ex. - color or layer. Suggestion: Make sure your boundaries are on their own unique named layer and it should work. Edited August 10, 2010 by ReMark Quote
degoos Posted August 10, 2010 Author Posted August 10, 2010 but I can't get into the quickselect dialog box, when I do select objects in the hatch dialog box and I try to type qselect, it doesn't work, it says: "Select objects or [picK internal point/remove Boundaries]" Quote
ReMark Posted August 10, 2010 Posted August 10, 2010 Really? Then you must be doing something wrong. I drew four circles on a layer named HatchBoundary. I used Qselect and set Properties to Layer and set the Value to HatchBoundary. When I click on the OK button all the boundaries are selected. Next I start the Hatch command. I set my Pattern, Angle and Scale. Then I press the Add: Select Objects button. Finally, I click on the OK button. When I am returned to my drawing all the circles have been hatched. I did not pick them in any manner (singlely or as a windowed group). From my AutoCAD text window: Command: qselect 4 item(s) selected. Command: hatch 4 found Quote
degoos Posted August 10, 2010 Author Posted August 10, 2010 I did the same thing you did and now it works, don't really now what I did wrong before, but thanks! grtz, degoos Quote
ReMark Posted August 10, 2010 Posted August 10, 2010 I ran into the same problem when I first tried it myself. I thought it was a typing mistake and just kept at it. It only took me three tries! Glad to hear you got it to work. Quote
