Dear all,
I would like to freeze all layers but I don't the code is, I know if I turn off all layer by this,
(vlax-for item theLayers (vlax-put-property item "LayerON" ':vlax-false))
but when I try to use
(vlax-for item theLayers (vla-put-freeze item :vlax-true)) it got error.
Regards
Please don't forget that you cannot freeze the current layer. So you should filter it out from that list - may list it by CLAYER system variable.
Regards,
Why not use the standard command?
(command "_.LAYER" "_Freeze" (strcat "~" (getvar "CLAYER')) "")
I'm seeing more and more of avoiding a command for no real reason. My $0.02 -David
thanks ! msasu.
but how to write this code, forgive me I'm new in lisp. I got the following error message.
Command: (vlax-for item theLayers (vla-put-freeze item :vlax-true))
*Cancel*
Automation Error. Invalid layer
I suppose that the theLayers variable is a list holding layers entities, so you should ensure that skip current layer by comparing his name with the one stored in CLAYER system variable:
         (if (not (equal (vla-get-name item)
                         (getvar "CLAYER")))
          (vla-put-freeze item :vlax-true)))
Regards,
Try the following in sequence with no Lisp at all, and what's more. It will freeze all layers except the current one ;
-layer
F<enter>
*<enter>
<enter>
<enter>
Very simple .....
Regards,
Tharwat
Thanks ! msasu.
(getvar "CLAYER")))
Regards,
*hehe* yeah i noticed the same thing.
But David, dont you know that the other stuff is fancy!? Its just `clean' and `good-er' and `cooler'. I mean come on man, get with the times!
*lol*
Here is a quickie
( (lambda (/ layer)
   ;; (ex) Freeze all layers in drawing using Visual Lisp.
   ;; NOTE: This will be slower then other methods i would use.
   ;;            I would not use this in my code.
   ;; By: Se7en
   ;; 08.11.10 08:18:00 AM
   (vlax-for
       layer
   (vla-get-layers
     (vla-get-activedocument
       (vlax-get-acad-object)))
       (if (and
      (vlax-get-property layer 'Freeze)
      (not
	(eq
	  (vlax-get-property layer 'Name)
	  (getvar 'clayer))) )
             (vlax-put-property layer 'Freeze :vlax-true)))) )
My offering:
(defun c:FreezeAll ( / def )
 ;; © Lee Mac 2010
 (while (setq def (tblnext "LAYER" (not def)))
     (lambda ( elist )
       (if elist
         (entupd
           (cdr
             (assoc -1
               (entmod
                 (subst
                   (cons 70
                     (boole 7 1
                       (cdr
                         (assoc 70 elist)
                   (assoc 70 elist) elist
     (cond
         (eq (getvar 'clayer) (cdr (assoc 2 def))) nil
         (entget
           (tblobjname "LAYER"
             (cdr
               (assoc 2 def)
*lol*
We must just be showing our age..... and I get in trouble every time I try to be fancy -David
K.I.S.S., I like this one.
(command "_.LAYER" "_Freeze" (strcat "~" (getvar "CLAYER[color="red"]'[/color])) "")
Please notice the quote which highlighted above.
  • 3 years later...
You save my life this sequence its perfect for my macro Thanks
