Inserting hyperlink to excel through visual lisp
Ahankhah
Hi,
I am writing a visual lisp program, invoking Microsoft Excel to make modificatins in an existing .xlsx fle.
How can I put a hyperlink text inside a cell?
Mehrdad Ahankhah
@Lt Dan's legs: Absolutely NO! By opening an Excel file (a formatted file) in text mode you will destroy it! Check on the forum, there are already examples regarding Excel file access from AutoLISP available.
Regards,
I'm not sure I completely understand your question Ahankhah: do you wish to link two text items in AutoCAD & Excel so that if one is modified, the change is reflected in the other?
Or are you merely looking to copy a text item to Excel? Or use a hyperlink in AutoCAD to open Excel?
Lee Mac, I found the solution of my instant problem, but you mentioned to the subsequent question of me. Do you know how I can link a text in a cell of excel spreadsheet to some information about an drawing:?? For instance, am I able to show the number of lines in a drawing in an excel file, so that when the number changes the text in excel spreadsheet changes to the new amount:huh:? I hope I could express my idea:unsure:!
Mehrdad Ahankhah
www.irancad.com
Lt Dan's legs,
although msasu is right, you gave me the clue.
Here is my code using your offer:
(vl-load-com)
(setq excel     (vlax-create-object "Excel.Application")
     workbooks (vlax-get-property excel 'Workbooks)
     workbook  (vlax-invoke-method workbooks 'Open "test.xls")
     sheet     (vlax-get-property excel 'Activesheet)
     cells     (vlax-get-property sheet 'Cells)
     data      '("This"                "is"
                 "an"                  "example"
                 "of"                  "inserting"
                 "text"                "and"
                 "hyperlink"           "in"
                 "excel"               "spreadsheet:"
                 "=HYPERLINK(\"cadtutor.net\";\"cad tutor\")"
(setq row 1)
(setq column 0)
(foreach item data
   (setq column (1+ column))
   (vlax-put-property cells 'Item row column item)
(vlax-invoke-method workbook 'Save)
(vlax-invoke-method workbooks 'Close)
(vlax-invoke-method excel 'Quit)
(vlax-release-object cells)
(vlax-release-object sheet)
(vlax-release-object workbook)
(vlax-release-object workbooks)
(vlax-release-object excel)
(gc)
I appreciate your help and want to thank you:D.
Edited by Ahankhah
changed , to ; in the code: "=HYPERLINK(\"cadtutor.net\";\"cad tutor\")"
Mehrdad Ahankhah
www.irancad.com
Hmm.. a tough one - a reactor springs to mind, but it wouldn't be easy to implement. Unless there is a way to somehow accomplish this with fields...
