ajcarr4 Posted August 11, 2010 Posted August 11, 2010 I am using a library in autocad 2010 but the lsp file does not automatically load. I use the lsp command and find the file I need and load it in, but I need to do this every time I start up autocad. Is there a way to store it so I do not need to reload it every time? I also have it linked in the support file search path. I am not 100% how it works but i thought that might help. If anyone has a guide to how LSP files work that would be helpful. Quote
MSasu Posted August 11, 2010 Posted August 11, 2010 Place those files in StartUp Suite list (files that are automatically loaded when you open AutoCAD) - the button from low-right corner of that dialog. Or do a search on Forum for acaddoc.lsp file usage. Regards, Quote
ajcarr4 Posted August 11, 2010 Author Posted August 11, 2010 Place those files in StartUp Suite list (files that are automatically loaded when you open AutoCAD) - the button from low-right corner of that dialog. Or do a search on Forum for acaddoc.lsp file usage. Regards, That sorted it. Thanks! Quote
