AutoCAD & screensaver issue
Hi there,
Haven't heard from me in a while, miss me? ;)
Anyway my problem is, when I leave my computer and come back the screensaver is usually on. When the screensaver turns off (by moving the mouse and typing, etc..) AutoCAD crashes (I get the error report). I'm curious to see if there is any reasons why? I'm getting into the habit of hitting save when I leave my computer for a few minutes.
What are the specs on your computer? Screensaver issues were a big problem in the past due to memory conflicts/constraints.
Are you doing 3D-modelling? I have had this (and other issues) when I leave the computer with a 3D-model up.
And, oddly, when I leave a video on pause in Firefox and the screensaver kicks in, Firefox crashes. (not that I think they are related) :?
Thanks for the replies!
Umm well here's the information from the Control panel:
2.13 GHz, 2.99 GB of RAM
And I haven't done 3D modelling yet. These are just regular 2D drawings.
What happens if you disable the screensaver?
If you're running one of those aftermarket screen savers with animation, you may as well be running a DVD.
I use (NONE) for a screen saver, and let Windows turn off the display after 20 minutes of non-use. That's one advantage of an LCD monitor, it just blinks right back on.
I have had screen saver conflicts in the past with Acad 07, but not with newer stuff. There's no reason for a screen saver unless you're using a 1982 monochrome CRT monitor. The screens don't burn in anymore.
Dana beat me to it, no screen saver. Use power options to just blank out the monitor.
The LCD monitors are great but, I miss the old ViewSonic 22" graphic monitor I had. I gave it away to
gain desktop real estate.
Don't know why I miss the CRT, just sentimental I guess.
Tank: I think you miss it because of the 4:3 aspect ratio. Just seems more natural. Perhaps we are showing our age! LOL
Yes ReMark gettin' used to the wide sceen took awhile.
And you bet, wouldn't go back now.
  • 4 months later...
I had issues with some screensavers knocking over Autocad and giving me some really trippy video errors. And as for widescreens, i fill them up to give my 4:3 aspect back :)
We have the same problem as SwChilly, but only on one computer. Its an HP Z400 4GB RAM and two 24" Samsung monitors and it only happens with AutoCAD Civil 3d 2011. We have a Windows 3D object as the screen saver.
I'm surprised anyone even uses screensavers any more. Kids like them though. I think they find them mildly entertaining for about the first 30 seconds.
I don't know if they are still this way, haven't looked at a screen saver file in years, but the problem used to stem from the fact that screen saver files had a file extension of ".scr", and Autocad used that same extension for script files. Somehow during the waking up process from running the screensaver, Autocad would think it was supposed to run a script and crash because it of course couldn't run the screensaver file. This was back in the old R12, 13 and 14 days. 13 was really bad about it (13 was bad, period).
No way, I am old school too and I welcomed wide screen monitors with open arms. I guess I worked on more rectangle designs than square ones ;)
Not sure if the OP answered this but I want to see what video solution they are using. I saw the cpu and ram specs but that is not the whole picture.
Not a bad habit to get into regardless.
Save early. Save often.
use autosave! then you don't have to remember! I have often thought about asking Autodesk to rename it to "save your....backside" but i don't think they would do it. Shortcut key could then be sya.... just a though.
