if i have line & text in INSERT (block) object.
how to retrive list of that object entities?
i mean in BLOCK or INSERT objects?
(entget (car (nentsel)))
will get you the entity list of an entity in a block
yeah, but i dont want to select object.
i have for example this:
Command: (setq [b]my-block[/b] (entget (entlast)))
((-1 . <Entity name: 7ef9e050>) (0 . "INSERT") (330 . <Entity name: 7ef65cf8>)
(5 . "BA") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 .
"AcDbBlockReference") (2 . "test") (10 3.38842 8.55032 0.0) (41 . 1.0) (42 .
1.0) (43 . 1.0) (50 . 0.0) (70 . 0) (71 . 0) (44 . 0.0) (45 . 0.0) (210 0.0 0.0
1.0))
how do i retreve list of all Entity names in my-block?
Every Block Reference contains the same entities set. You need to extract the Block Definition from BLOCK table and use ENTNEXT function to find all nested entities:
(defun GetEntitiesList(Name / blLst cEnt oLst)
 (if(setq blLst(tblsearch "BLOCK" Name))
     (if(setq cEnt(cdr(assoc -2 blLst)))
  (setq oLst(list cEnt))
  (while(setq cEnt(entnext cEnt))
    (setq oLst(cons cEnt oLst))
    ); end while
  ); end progn
); end if
     ); end progn
   ); end if
 oLst
 ); end of GetEntitiesList
Example of usage:
Command: (GetEntitiesList "01-06-Adr_Isolator")
(<Entity name: 7efe2508> <Entity name: 7efe2500> <Entity name: 7efe24f8>
<Entity name: 7efe24f0> <Entity name: 7efe24e8> <Entity name: 7efe24e0> <Entity
name: 7efe24d8> <Entity name: 7efe24d0> <Entity name: 7efe24c8> <Entity name:
7efe24c0> <Entity name: 7efe24b8>)
i have made adjustments to my needs.
ename instead blkname for arg.
function gives me back just text entities from block.
(DEFUN
  txtlstfromblk (ename / c txtl bllst cent olst tmp)
(IF (SETQ bllst (TBLSEARCH "BLOCK" (CDR (ASSOC 2 (ENTGET ename)))))
 (PROGN
  (IF (SETQ cent (CDR (ASSOC -2 bllst)))
   (PROGN
    (SETQ olst (LIST cent))
    (WHILE (SETQ cent (ENTNEXT cent)) (SETQ olst (CONS cent olst)))
    ) ;_ endPROGN
   ) ;_ endIF
  ) ;_ endPROGN
 ) ;_ endIF
(SETQ c (LENGTH olst))
(WHILE (>= (SETQ c (1- c)) 0)
 (SETQ
  text?
  (CDR (ASSOC 0 (ENTGET (SETQ tmp (CAR olst)))))
  olst
  (CDR olst)
  ) ;_ endSETQ
 (IF (= text? "TEXT")
  (SETQ txtl (APPEND txtl (SETQ txtl (LIST tmp))))
  ) ;_ endIF
 ) ;_ endWHILE
txtl
) ;_ endDEFUN
for
Command: (setq my-block (entlast))
function call (txtlstfromblk my-block)
Replacing (= text? "TEXT") with another type, can be used for
retrieving other entity types.
