manikuruvilas Posted August 12, 2010 Posted August 12, 2010 hi all, let me giv u an example of what i want... i have a building plan and i have drawn an elevation of it by extending construction lines... (nothin new) now i keep dat plan at an angle... to draw the elevation of that, i dnt hav to extnd construction lines again but i jst hav to stretch/shrink the previous elevation. i wnt to kno hw dat can be done... does any1 have an idea...i hope u got wat i wnt to do... i have read the results of making it a block and scaling it...but what i have seen was much easier. i hav nt been abl to find answr anywhr...i have seen people use it looong bak and i too knew it...jst dat i hv forgottn hw to do it... Quote
ReMark Posted August 12, 2010 Posted August 12, 2010 Are you talking about the STRETCH command? Otherwise, rescaling a drawing in only one direction would normally require the object be a block and inserting it with different X and Y scale factors. Quote
manikuruvilas Posted August 12, 2010 Author Posted August 12, 2010 i dnt kno if thers an option in stretch which enables u to do it but am sure its not my making it a block and then inserting it with diffrnt x and y values... it is sumthin similar to the way we scale with refernce to a desired distance by not actually entering the values... Quote
Tiger Posted August 12, 2010 Posted August 12, 2010 ... i wnt to kno hw dat can be done... .... Would it take so much longer to write I want to know how that can be done ? Quote
ReMark Posted August 12, 2010 Posted August 12, 2010 Maybe the OP's keyboard is missing some letters? Quote
mdbdesign Posted August 12, 2010 Posted August 12, 2010 Would it take so much longer to write I want to know how that can be done ? Unless he is using Blackberry while driving... Quote
manikuruvilas Posted August 13, 2010 Author Posted August 13, 2010 i dnt know where the discussion was heading to.. however, hey remark, i guess alligning it wil again scale it in both directions... wil try again and inform in case i get thru sumthn Quote
Tiger Posted August 13, 2010 Posted August 13, 2010 i dnt know where the discussion was heading to..,.. I was trying to make the point that it doesn't take much more time to write out the actual words than your shortened versions that (for me at least) distracts from your question and makes me less prone to help. Quote
ReMark Posted August 13, 2010 Posted August 13, 2010 man: Please post a dwg or image file so we can have some idea of what you are working with. Thanks. Quote
