Pressing freeform object thru solid
jgcarp
HI,I'm trying to press on odd shaped enclosed object thru a solid to form an opening.I created this shape by forming a V shape w/ spline command and enclosing
the V with an arc.It won't press thru.Seems like it's not being recognized as an en-
closed object. I've pressed holes with all other types of shapes and they all work fine, but not the spine/arc combination.Any help is greatly appreciated!
Probably just convert to surface extrude and subtract... Press-Pull is picky sometimes...
KC
Attach the file exhibiting this behavior here.
