I am missing my utility panel... I have already right-clicked in the Home Ribbon, and it does not even give me "Utility" as and option. Advice please?
The Utilities panel, right?
And when you right click on another panel, and you see the flyout that says Tabs and Panels when you click on Panels the expanded list does not have Utilities among the choices?
When did this first occur?
Have you been customizing your CUI?
Yes, the Utilities Panel. Correct, Utilities is not among the choices.
I had to re-load AutoCAD 2010 due to network system errors. Once I reloaded it, it has been nothing but trouble for me.
I have entered my CUI a couple times, but I was following some other advice. I didn't do anything else. I barely understand the CUI.
Reload AutoCAD as in uninstall it and then reinstall it right?
I would have recommended trying the REPAIR option first.
I'm on a standalone system so I am not familiar with network deployments per se. I'd have to give it some thought. I assume the program is, however, loaded on your computer and it is the license and a few other incidentals that are accessed via the network. Is that correct?
Not exactly sure how it was re-installed... the IT guys did it virtually. What is the REPAIR option? And how do I access it?
Yes the program is loaded into my computer, and accessing and lisence are accessed via the network.
The REPAIR option should be listed under AutoCAD 2010 in the Add/Remove Software portion of your Control Panel. It may however require you to have the installation disk(s) available.
