cbuckner Posted August 17, 2010 Share Posted August 17, 2010 I am currently using Autocad Map 3D 2010, which uses alot of the same commands as AutoCad 2010. Atleast that is what i have been figuring out since i cannot find any help really online with trying to learn this version,(Map 3D), so i have just been learning the regular Autocad 2010. But that is another post. I must have changed a setting that affected this and not known it, but recently when I click Open to bring up the dialog box to search for and open a document or template the dialog box does not come. Instead it says "Enter name of drawing to open <.>:" in the command line. Does anyone know how to get the dialog box to start coming up again? Quote Link to comment Share on other sites More sharing options...
cbuckner Posted August 17, 2010 Author Share Posted August 17, 2010 Disregard this thread. Sorry im a newbie. After i posted this the similar threads popped up down below and i think i have found my answer. Thank you anyways. Quote Link to comment Share on other sites More sharing options...
