Michaels Posted August 18, 2010 Posted August 18, 2010 hello, I wonder how to get only the longest line from a ssget only ! Any suggestion? Just a start. (setq ss1 (ssget '((0 . "LINE")))) (if ss1 (progn (setq i 0 total 0 n (sslength ss1)) (while (< i n) (setq e (entget (ssname ss1 (setq i (1+ i))))) ) )) Thanks Quote
Kerry Brown Posted August 18, 2010 Posted August 18, 2010 If I say : step through the selection set, save the ename and length of the first entity. then; if the next line is longer overwrite the ename and length repeat repeat you will be left with the longest length and the ename of the entity so it can be selected. There are several ways to handle this, of varying complexity but this may be an easy way to design a solution. Quote
Michaels Posted August 18, 2010 Author Posted August 18, 2010 Thanks Kerry. I added the following codes to the above selection set, and it gets the longest number but with the following msg. (setq ename (distance (setq pt1 (cdr (assoc 10 e)))(setq pt2 (cdr(assoc 11 e))))) (setq longest (entnext (max ename))) Here is the msg . ; error: bad argument type: lentityp 8.57792 What's wrong or missing code ? Thanks, Quote
Kerry Brown Posted August 18, 2010 Posted August 18, 2010 Before you start running learn to walk. Are you able to step through the selection set and print eack line length to the commandLine ? Quote
David Bethel Posted August 18, 2010 Posted August 18, 2010 There a lot of things that can make a this kind of simple sounding routine very tricky: 2D or 3D distances? WSC lines only? Do you need to filter out paperspace lines? What happens when you have multiple maximum length lines? Does the end result need to be a selection set of just a ename? [b][color=BLACK]([/color][/b]defun c:mxline [b][color=FUCHSIA]([/color][/b]/ i mx ss en ed ld ll[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq i -1 mx 0 ss [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color] '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]0 . [color=#2f4f4f]"LINE"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss [b][color=BLUE]([/color][/b]setq i [b][color=RED]([/color][/b]1+ i[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b] ld [b][color=GREEN]([/color][/b]distance [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc 10 ed[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc 11 ed[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]if [b][color=GREEN]([/color][/b]>= ld mx[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]setq mx ld ll [b][color=BLUE]([/color][/b]cons en ll[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]princ [b][color=NAVY]([/color][/b]strcat [color=#2f4f4f]"\nMax Length = "[/color] [b][color=MAROON]([/color][/b]rtos mx 2 4[b][color=MAROON])[/color][/b] [color=#2f4f4f]" - "[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1 ll[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] ll contains a list of enames of the longest lines. -David Quote
Michaels Posted August 18, 2010 Author Posted August 18, 2010 Before you start running learn to walk. :lol:Are you able to step through the selection set and print eack line length to the commandLine ? The answer is YES. Here it is complete but small error at last entity distance , (defun c:long (/ ss1 i total n e len) (setq ss1 (ssget '((0 . "LINE")))) (if ss1 (progn (setq i -1 total 0 n (sslength ss1)) (while (< i n) (setq e (entget (ssname ss1 (setq i (1+ i))))) (setq len (distance (setq pt1 (cdr (assoc 10 e)))(setq pt2 (cdr(assoc 11 e))))) (print len) )) ) (princ) ) Here is the response of codes, 20.0628 9.89551 17.8955 10.8955 ; error: bad argument type: lentityp nil Could you please indicate to the wrong thing in the routine. Great Thanks. Quote
CHLUCFENG Posted August 18, 2010 Posted August 18, 2010 One too many n's [color=black](defun c:long (/ ss1 i total n e len)[/color] [color=black] (setq ss1 (ssget '((0 . "LINE"))))[/color] [color=black] (if ss1[/color] [color=black] (progn[/color] [color=black] (setq i -1[/color] [color=black] total 0[/color] [color=black] n (sslength ss1)[/color] [color=black] )[/color] [color=black] (while (< i ([color=red][b]1- n[/b][/color]))[/color] [color=black] (setq e (entget (ssname ss1 (setq i (1+ i)))))[/color] [color=black] (setq len (distance (setq pt1 (cdr (assoc 10 e)))[/color] [color=black] (setq pt2 (cdr (assoc 11 e)))[/color] [color=black] )[/color] [color=black])[/color] [color=black](print len)[/color] [color=blue];;; added this for original question[/color] [color=blue](if (> len total)[/color] [color=blue] (setq total len)[/color] [color=blue])[/color] [color=blue] )[/color] [color=blue] )[/color] [color=blue] )[/color] [color=blue] (princ[/color] [color=blue] (strcat "\nLongest line in selection set is " (rtos total))[/color] [color=blue] )[/color] [color=black] (princ)[/color] [color=black])[/color] Quote
fixo Posted August 18, 2010 Posted August 18, 2010 Here is my 2 cents (defun C:demo(/ filter_list info_list max_len ss) (defun ent_length (line) (distance (cdr (assoc 10 (entget line))) (cdr (assoc 11 (entget line))) ) ) (if (setq ss (ssget '((0 . "LINE")))) (progn (setq info_list (mapcar (function (lambda(x) (cons (ent_length x) x ))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))) (setq max_len (apply 'max (mapcar 'car info_list))) (setq filter_list (vl-remove-if (function (lambda(x) (not (equal (car x) max_len 0.01)))) info_list) ) ;; do your things here: ;;/* (foreach item filter_list (command "._change" (cdr item) "" "_P" "_Color" "_Red" "") ) ;;*/ ) (alert "Nothing selected") ) (princ) ) ~'J'~ Quote
Lee Mac Posted August 18, 2010 Posted August 18, 2010 My 'entry' (defun c:GetLongestLine nil ;; © Lee Mac 2010 ( (lambda ( ss i / e m d l ) (and ss (while (setq e (ssname ss (setq i (1+ i)))) (if (< m (setq d (distance (cdr (assoc 10 (entget e))) (cdr (assoc 11 (entget e)))))) (setq m d l e) t ) ) (sssetfirst nil (ssadd l)) ) ) (ssget '((0 . "LINE"))) -1 ) (princ) ) Quote
fixo Posted August 18, 2010 Posted August 18, 2010 If the several lines have the same length then... Quote
alanjt Posted August 18, 2010 Posted August 18, 2010 (defun c:SLL (/ ss) ;; Alan J. Thompson, 08.18.10 (if (setq ss (ssget '((0 . "LINE")))) ((lambda (i / e l v d lst) (while (setq e (ssname ss (setq i (1+ i)))) (or (< (setq v (distance (cdr (assoc 10 (setq l (entget e)))) (cdr (assoc 11 l)))) d) (setq d v) ) (setq lst (cons (cons v e) lst)) ) (sssetfirst nil ((lambda (add) (foreach x lst (and (equal (car x) v) (ssadd (cdr x) add))) add) (ssadd) ) ) ) -1 ) ) (princ) ) Quote
