Halden Posted August 26, 2010 Posted August 26, 2010 (edited) Hi Mate I think in order to have your spot lights work with your daylight environment ,i suggest you to use some dark color bulbs or cover the spot lights with the dark color.Otherwise sun day light would cover all your spotlights which you cannot see even when they were on. Edited August 26, 2010 by fuccaro Hyperlink removed Quote
Cad64 Posted August 27, 2010 Posted August 27, 2010 If you cover the lights, how are you going to see them? And if you use dark colored bulbs, they won't cast normal, natural light In order to see lights, while using the daylight system, you have to ramp up the intensity, as I have already explained. Quote
funk Posted August 29, 2010 Author Posted August 29, 2010 Yeh I have not really tried to set the spot lights to contrast the Sunlight system so as to see the spot lights, but it seems it is just a case of using photometric lights for starters, and then focusing on intensity. This worked well for me. Cheers for the advice but I f there's something I have learned its that there is usually more than one way to achieve the results you want so I'll have a look at it. Quote
markdavis709 Posted April 19, 2011 Posted April 19, 2011 (edited) Hi, Thanks for all the information guys. I am beginner at this work and all your suggestions are very helpful for me. Edited April 19, 2011 by Tiger removed links Quote
