don Posted August 20, 2010 Posted August 20, 2010 I am asking if there is atut about lofting square to round trans pieces to get the proper flat sides Quote
linnmaster Posted August 20, 2010 Posted August 20, 2010 Not quite sure what you mean by "proper flat sides"? Are you referring to a development? Regards, David. Quote
ReMark Posted August 20, 2010 Posted August 20, 2010 Wouldn't that be done automatically? Can you loft a square to a round and have rounded sides? Just curious. Quote
JD Mather Posted August 20, 2010 Posted August 20, 2010 (edited) Lofted Flange - Inventor 2010 and later. Seems to me I recall that there is a built in tutorial in the Help>Learning Tools>Tutorials. Here is an example http://forums.autodesk.com/autodesk/attachments/autodesk/78/382121/1/DF%20High-Speed%20Abort%20Gate-24.7.png By the way - you can use full words and sentences here in describing problem statement. Edited August 20, 2010 by JD Mather Quote
don Posted August 22, 2010 Author Posted August 22, 2010 Thanks found the lofted flange in sheet metal. Quote
