gbradley Posted August 20, 2010 Posted August 20, 2010 I just started going through the Ribbon tutorial and the eight subject down says Switch to an Environment. I don't see the option to click the stress analysis command. Is this an add on that I do not have? Is the tutorial from an earlier version? I am using Inventor 2010 Thanks Quote
JD Mather Posted August 21, 2010 Posted August 21, 2010 You have to have Inventor Professional or Inventor Analysis - you cut off the top of the screen so I can't tell what version you have. You can go to Help>About Autodesk Inventor.... to see what version you have. Quote
gbradley Posted August 23, 2010 Author Posted August 23, 2010 AutoCAD Inventor Suite 2010 Standalone - Locked Man, I thought I had the Shnizzle, come to find it's an also ran. :-) Quote
JD Mather Posted August 23, 2010 Posted August 23, 2010 Man, I thought I had the Shnizzle, come to find it's an also ran. :-) If you are a student or faculty you can download Inventor Professional for free from http://www.autodesk.com/edcommunity Quote
